Tein SS install with heeltoe tophat kit
Old Jun 18, 2010 | 05:43 PM
domrep001's Avatar
Hey I was wondering if anyone can help me with this or run into the same problem... I installed the Tein SS coilovers today using the tophat kit from HeelToe. I noticed the kit just came with the bushings (type S), bump stop, base hat, and base rubber. I figured that was all there was to it... even after looking at the Acuraoemparts web site suspension parts diagram... I saw that there was a collar and upper washer also on the stock suspension, but thinking that I had all the parts I needed I went ahead and installed it with the parts I had. It seemed like everything went on fine and fit. The front seems like its ok, but I get a clunking noise in the rear for any little bump and an occasional squeak... I did a search and noticed people had problems with endlinks or loose nuts, bolts but that isnt the case. Did I need that upper washer and collar? Thought I ask before I take everything apart again.
Old Jun 18, 2010 | 07:43 PM
KzooTL's Avatar
05' AT SSM
Yeah i'm wondering the same thing, interested in swapping making the coilovers a direct swap with oem suspension and looking for all parts for a direct swap.
Third post down i have the diagrams of front and rear suspension, just not sure if i need everthing.
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/part-numbers-top-hats-766038/
Old Jun 18, 2010 | 10:54 PM
domrep001's Avatar
check out this post it might help you.... http://www.acura-tsx.com/forums/showthread.php?t=733536
As for me, I think I have to get that washer.... the tophat stack seems loose from what see when I checked.
spoiler900
May 25, 2016 10:16 PM
handsom-hustla
Nov 13, 2015 05:04 PM
InFaMouSLink
Oct 27, 2015 06:51 PM
IIDXholic
Oct 8, 2015 07:53 AM
HOWELLiNC
Sep 10, 2015 01:39 PM
