Tein S.Tech Lowering spring
Darryl
found a set on ebay $200
does any1 have these on their TL and what do you think about them
should i get them
Fit: Acura 04-06 TL (UA6, V6, 4Dr)
Part Numbers: SKA52-AUB00
Lower rate(Front/Rear): -1.2/-1.3 inch
Spring rate(Front/Rear) : 307/196 lbs/inch
should i get them
- TEIN S.TECH Lowering Spring give you more aggressive appearance and better handling.
- Rubber spring protector tube to prevent noise.
- High quality Lowering spring with reasonable price.
- Special green coating and painting treatment to prevent rust
Former Sponsor
No need to buy from ebay. We have these also available and for around the same price:
http://store.excelerateperformance.c...0/i-35062.aspx
Under construction
I have these springs. If you have money, buy coilovers, skip the lowering springs. The drop is ok and the car is kinda wobbly. For me its a temporary solution. My shocks are still ok though, no problems at all. I've had them on for about 12K miles.
Ive had the Pro Kit on my Civic backin the day with the stock shocks wasnt bad. I liked it. Than switched to the Groundcontrol coilovers with new replacement shocks nothing fancy on the shocks and were okay. But this interests me alot because this is on my need to know informations also.
Very!
Yup, ran the Eibachs with the OEM shocks for a year before the Konis....the OEMs worked great, very complaint ride!
Be aware though that the Eibachs make the car sit perfectly level front to back. So you lose the rake which *may* give the illusion of the car "sagging" in the rear, which is not the case.
My car just sat level...but I like a slight rake from the front to the back.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
