Tein Dampers- Street Advance Dumb Question
Hey all,
just ordered coilovers from thmotorsports and because i've read that tein street advance doesn't come with top hats, i've proceeded to look to purchase them as well as the bushings.
As the uneducated foolish slave to consumerism buyer that I am began to thought, "Wait what if my coilovers came with top hats?!" I proceeded to check my e-mail and it seems as if these are included with my purchase.
TEIN Dampers - Street Advance (GSA80-2USS2)
Street Advance Coilover Kit
OEM Front Upper Mount
OEM Rear Upper Mount
EDFC Compatible, Requires Motor EDK05-10100
Ride Height Range (F) : -2.9~-1.1in (-73~-29mm)
Ride Height Range (R) : -2.6~-1in (-66~-26mm)
Spring Rate (F) : 672lbs/in (12kgf/mm)
Spring Rate (R) : 336lbs/in (6kgf/mm)
Spring Size (F) : 200mm L / 70mm ID
Spring Size (R) : 250mm L / 70-90mm ID
Now, am i stupid or does my system come with top hats. Stupid question I know, but are oem front upper mounts and oem rear upper mounts not the same as top hats? Thank you!
nanos
11-12-2015 08:41 PM
Puma Jim
09-26-2015 01:08 AM
wusty23jd
09-24-2015 11:41 AM
