Tein Basic Installed, Review
Got them installed. Took about 5hrs.
The toughest part was removing the back seat. This is where you need to slide your arm underneath and loosen the two bolt right underneath the rear headrests. Talking about going in Blindfolded.
I used this DIY. It's quite similiar to 3G TLs. Hence my reason not to make one myself.
http://www.abunchofcars.com/diy_page...ng_install.htm
A side note:
Tein instructions does not indicate to make a mark of the lockseat with the shock. This is helpful to note how many turns you're making when you want to adjust the height after the installation.
Likewise, Tein instructions indicate that the car should not be lower more than 13 inches when measured from fender to center of wheel. This is very important due to the spring rate that comes with the Basic Setup.
Also, if you jacked the car up from the front using the cross member of the car, then you will have a problem lowering the car when the Teins are installed. There's a mud deflector underneath that is lower than the front bummper. That piece will get crushed. It's important to use another jack and jack one of the sides up before lowering the front jack. (This is in conjunction that you're already using jack stands prior to keep the car up. Don't ever depend on the floor jacks to keep the car up.)
Review:
The car is super lower when set at 13 inches. The ride is quite rough on mild bumpy streets. However, on smooth streets, the handling is awesome.
I tried to drive with this setting for a day and it was too harsh for my taste. Therefore, I brought it up to about 1 inch. Measured from fender to center of wheel is 14 inches.
The ride is way much better, plus I don't lose the superb handling. The actual wheel gap went from a tight 1 finger to a tight 2 fingers.
I forgot to measure the stock height. If someone with stock suspension can measure and give us the #, then I'll know how much the car has been lowered.
Cost:
My total cost for Teins Basic was $640. Included tax and no shipping since I did local pickup and paid cash.
http://www.optionimports.com
Alignment:
I haven't done it yet, but will after the holidays. I know that the rear has butterflied a bit. The comptech camber kits for fronts and rears are made by Specialty Products Company: http://www.specprod.com
You will need: Fronts (#67320) Rears (#67095)
Pics:
None yet. I'm waiting for my rims. Once I have them on and the car aligned. I will post the pics. But like Tein's website, the car looks exactly the same as the one posted (minus the 1 inch raised).
Wheels:
19x8.5 is the best fit. Now that it's lowered, I know that the 19x9 will definitely rub. Thanks for those that have made comments on the other thread.
A side note:
Review:
Cost:
Alignment:
Pics:
Wheels:
A side note:
Review:
Cost:
Alignment:
Pics:
Wheels:
A side note:
Review:
Cost:
Alignment:
Pics:
Wheels:
my springs settled & i got an alignment. the front is fine. the back passenger is -1.5 camber and the driver's rear is -3.2. i put the springs in after i had my car repaired. someone drove into my rear side & hit the quarter panel & scraped the wheel. so i dont know if it's just the lowering( h&r 1.4f 1.3r springs only) or if it's because of the hit, which was not too hard. i really need advice because it's bothering me
Former Sponsor
It probably has to do with the repair, but getting a camber kit for the one side is a band-aid.
Former Sponsor
so if i just get a camber kit for the back, it'll straighten out? is that what u would do in my situation?
thanks
thanks
It depends on your motivation for straightening it out.
If you don't like the look, then yes get the camber kit.
If you are worried about your tires, I would not worry about it.
2006 TL-S.C. 6mt
THANKS TO MR. HEELTOE, HE ANSWERED MY QUESTION IN FLORIDA!!!!
YOU ROCK MAN!!
A side note:
Review:
Cost:
Alignment:
Pics:
Wheels:
A side note:
Review:
Cost:
Alignment:
Pics:
Wheels:
Former Sponsor
Originally Posted by MaszTL
Hey man do you still have the tein basics on your tl? If so, how do you like them? Does the EDFC work with them also? I don't think so but just thought I'd ask. Thanks.
The EDFC is used to adjust the dampening stiffness on adjustable coilovers. The Basics are non-adjustable, so the EDFC is not applicable. You'd need the SS kit to use the EDFC.
Marcus
wait y r u going in blindfolded??? u raise the rear headrest and theres a piece of leather over lapped...looks like a clit LoL!!! u open apart n stick ur socket in there 10mm unscrew just a lil bit and the seats raise up n off.
5 hours? We do this in 2. We don't remove the whole back seat. You can do it by just tilting the backrest part forward.
Technically, to avoid tire wear, camber kits are not needed. Just get a good alignment and your tires will be fine with some negative camber there.
Garage Park / Ikon
yup a lot of people dont realize that tire wear has a lot more to do with toe in/out than camber
A side note:
Review:
Cost:
Alignment:
Pics:
Wheels:
A side note:
Review:
Cost:
Alignment:
Pics:
Wheels:
Tein Basic or Tein SS ??????? I can't make up my mind if the SS are worth the extra $$$. I wish I could have a ride in a car equipped with Tein Basic lowered about an inch or so.
I dont think the ss are necessary if your not putting it on a track. Basics are stiff enough. I rode in a 240 wit basics and the car handled like a dream for the streets and highways.
Nice thread bump newb!! This thread is almost 6.5 yrs old.
nice thread bump. Didn't wanna start a new thread about this.
4cyl Accord tein basics on a 05 TL?
on tein site, tein basics for v6 and 4cyl are the same part number. I know that v6 accord suspension fits TL as I have accord spring/shock combo on now. Top hats are different I know that.
I know spring compression rates for 4cyl and v6 accord for tein basics are 504 lb/in and for a TL is 671 lb/in.
Is that too big of a difference and how would that affect the ride? Would it have too great affect on the shocks, making them wear out prematurely? Or would the car just sit a little lower?
spring rate on progress springs I have now is 320 lbs/in. Is spring rate differently measure or looked at between coils and springs?
Joseph Stansbury
34
12-04-2015 01:57 PM
handsom-hustla
11-13-2015 05:04 PM
nanos
11-12-2015 08:41 PM
