Stern Wheels
Registered Member
Stern Wheels
Who all is running Stern Wheels. Can you post pictures and tell me what you think about the wheels? I am looking at getting a set of 19 inch Stern ST-1 wheels with a +38 offset. Thanks Guys
https://acurazine.com/forums/showthr...rn+st-1+wheels
searched stern st-1 and it was one of the top threads. just don't be lazy and ppl will help you out
Registered Member
I have those exact wheels. Below is a post with a picture.
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/neuspeed-kit-before-after-pics-723520/
Help with my new stern wheels
I just got these from a friend and i have a couple of questions about it. They are 19×8.5 all around. My front tires are 245×40×19 and my rear tires are 255 35x19. I just talked to somebody from discount tires that my front tires should be 245×35×19 or i might experience rubbing. Is that true? Or what should i do? Or what should they be for a best setup and comfortable ride. This is my first car and first mod on my tl so i definitely need help.
I'm also experiencing noise and shaking when i hit a 50 on the freeway. Had the tires balanced when i got them installed. People talk about hub centric rings but i don't know what are those. What should i need or do to eliminate that issue?
I just talked to somebody from discount tires that my front tires should be 245×35×19 or i might experience rubbing. Is that true? Or what should i do? Or what should they be for a best setup and comfortable ride. This is my first car and first mod on my tl so i definitely need help. [/I]
Try the rings. That's the cheapest/easiest solution.
JByron
Jan 8, 2016 09:49 PM
