Stereotypical "Will This Fit" Thread
I hate to be this guy, but I can't seem to find an answer that seems to really answer my question. I was looking at a set of rims that are:
Diameter: 19 inch
Width: 8.5F and 9.5R
Offset +20F and +25R
Tires: 235/35/19F and 255/30/19R
my question is will they fit my 05 TL? I currently don't have any drop, but I plan on getting coilovers following rims. will these rub right now without a drop? look ridiculous? i don't really understand the offset, so I cant understand how they'd look. any help would be greatly appreciated
Diameter: 19 inch
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
WDP Type-S sitting on air
they will fit. you'll need a fender roll and a little camber depending on how much you drop the car. it wont look terrible but a drop will make it look a LOT better. post a pic of the wheels you are looking to get
also here is a simple article that gives a very basic understanding of wheel offsets
http://www.tirerack.com/wheels/tech/...jsp?techid=101
TheLT (01-12-2013)
Registered Member
Diameter: 19 inch
my question is will they fit my 05 TL? I currently don't have any drop, but I plan on getting coilovers following rims. will these rub right now without a drop? look ridiculous? i don't really understand the offset, so I cant understand how they'd look. any help would be greatly appreciated![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Diameter: 19 inch
Just know at stock height +20 and +25 will poke out past the fender. At stock height you may not need to roll the fenders, but once lowered you definitely will need to. A rear camber kit will also be necessary.
Based on you tire sizes, I assume you do not want a stretched look. I can tell you this no, based on experience a +20 offset up front with a 8.5" rim and 235 tire, you WILL rub. I was +23 with a 235 tire and on certain dips I could hear my fronts hit the fender liner. Also was 255/30/19 a typo? It should be 255/35/19.
Also, IMO, putting the rims on before you are dropped is going to look awkward. The TL already has a lot of fender gap stock, so adding 19's to that is really going to make the car look like a 4x4. Drop first, then rims.
TheLT (01-12-2013)
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
