staggered fitment help!!
whats up AZ..
newbie needs some lil advise here..
im planning on doing a staggered look on my 05 tl AT..
i was going to tun 18x7.5 front and 18x9.5 rear
the tl is on stock ride height as of now
my question is
would the 18x9.5 rub,need spacers,or would i get any problems for running this set up with stock ride height??
or should i just go with 18x8.5 for the rear??
thanks in advance guys!
my question is
run 18x8.5 upfront instead of 18x7.5 and in the rears 18x9.5 will work. if you have no plans on lowering your TL then you shouldn't have any issues with rubbing. however, i'd recommend lowering if your going to go with 18in wheels. the stock height and 18in wheels won't look good as far as appearance.
if it makes you feel any better there are a lot of members running far aggressive staggered fitment setups lowered. currently i'm running 19x10.5 with 275/30R19 tires in
the rear lowered.
i'd skip on the 18x7.5 upfront. too narrow. also, 18s... is there an option to go with 19s?
the rear lowered.
I have to agree. If there isnt an issue with going 19s then go for it. Staggered 18s with your offsets will be kinda small. I myself have 19x8.5 front and 19x9.5 rear and I couldve gone 19x9 front im sure but with negative camber. Its all up to you with what look your going for but Id suggest what DREW says
the rear lowered.
the rear lowered.
ok i was able to get more info on the wheels
the wheels that im getting they dont have 19 inch
just 18.
so they have 18x8.5 front
then 18x9.5 rear
the only thing is they only have 32 offset for the wheels
are there going to be any problems if i run this set up with the car not dropped??
just 18.
then 18x9.5 rear
adreano17
Sep 29, 2015 08:48 AM
nuldabz
Sep 3, 2015 05:49 PM
