Springs Question
Springs Question
I'm getting the TL soon White with Quartz / navi / 6 speed and i don't wanna void the warranty, they said i can go with the comptech springs. Are these ok on the car with 19's i'm looking at 1.7-2" drop Thanks
The 1" drop is very noticeable. I have the drop on my car currently, and I couldn't imagine going much lower. As it is, the car has a pretty low stance, so the extra little drop made a big difference. Also, as low as the TL already sits, there is no wasy that you could drop the car 2" and still be able to clear 19s without modifying the bumpers.
not true about comptech not voiding your warranty. its an aftermarket spring just like eibach would be. neither would automatically void your warranty but if its the direct cause of the part in question that has failed and needs to be repaired or replaced acura can void the warranty on that particular part(and it is up to acura to prove that the part did cause the problem). it cannot void the warranty on the whole vehicle just because you changed one component. you might find a dealer that will buy and install the comptech components and will warranty the comptech product just as it would oem acura replacement parts.
Originally Posted by cTLgo
The TL is very low as it is, going more than 1 in drop you will have to be EXTERMELY careful not bottoming out
Why isn't my signature showing up?
http://www.villagephotos.com/pubbrow...elected=847030
Not true...I drive full speed everywhere....barely slow down for most dips and speed bumps. Have yet to bottom out even once. I have only scratched that black plastic that hangs super low and that piece doesn't matter anyway.
Before comptechs
After
Hate to sound ignorant, but, can't follow those directions. It's active and on one profile screen it is checked. Where is "Go Advanced?
When you repsond to a thread, either click the quote button to get the other person's post in your response (as I have done here) or go down to the response box and click on go advanced as opposed to simply submitting the quick response. When you either quote or hit go advanced, you will get several options and your signature should work.
Comptechs here also. Very Happy with the 1" drop. No more.
Take a look at a WDP/MT/NAVI http://www.pwolly.com/EBAY/Dan/car.htm
I like the look of the 1" lowering but am concerned about rubbing!! Has anyone encountered issues with tires rubbing within the wheel wells? Can anyone also comment on the performance impact that was felt from installing springs? Has the spring installation helped out with the "torque steer"??
Thanks in advance!!
Thanks in advance!!
Thanks in advance!!
Thanks in advance!!
As far as performance, the car corners flatter and dive and squat are helped but not eliminated. I haven't noticed any differance with tourque steer. I don't know how lowering springs would help with that.
Michaelvg1 - Which kit do you have on yours? IMHO it's TOO low in the back for my tastes. In contrast, I like the drop on automata's car and he's got the comptech. If you tell me you have the comptech I'll think I'm going crazy...
jmoney2001
08-12-2019 06:23 PM
divac
08-29-2018 10:13 AM
1fatcrxnem1
22
06-01-2018 01:23 AM
