A-spec Tires
Hey all,
Buddy of mine has a set of brand new tires for sale. Hes looking for $250 for all 4. Tire size is 245/ 45 r18. Will these fit my 3G Chrome look A-specs rims? Thanks in advance.
My Garage not
those tires are too big for a 3G TL. the stock tire size is 235/40/18. you can go bigger and put a 245/40/18 on but a 45 series tire is too big and will throw the speedometer off.
i thought that acura recomends 225/40/18 for the 18x8 Aspecs!! Someone correct me if i'm wrong!!
^ +1
Here's the factory recommended specs. The recommended tire pressure has been later corrected in additional spec sheet, it's about 3 lbs higher than originally posted. So, like Princelybug said, 235/40/18 recommended. But many people prefer 245/40/18 for that little extra protection and better looks IMHO.
Hi guys
I'm very very very very very strict about tire pressure and here you have the CORRECT tire pressure for the same tire in the same wheel but in different model year TL
If you bought yout 18" wheels when you bought the car directly from the dealer, they should had put a sticker on the driver door with the right pressure you should put on the 18" tires, but if you got your rims (acura or aftermarket) and for whatever reason you dont have that so called sticker, here are the numbers, taken directly from each 18" Aluminum Wheel owners manual.
2004 235/40R18 95W Front 39psi (270kPa) Rear 36psi (250kPa)
2005 235/40R18 95W Front 35psi (240kPa) Rear 32psi (220kPa)
2006 235/40R18 95W Front 35psi (240kPa) Rear 32psi (220kPa)
2007 235/40R18 95W Front 38psi (260kPa) Rear 35psi (240kPa)
2008 235/40R18 95W Front 38psi (260kPa) Rear 35psi (240kPa)
all of these years are 3g TL's but the weight of the car is different, the center of gravity is different and that's why the tire pressure for front and rear tires is also different.
Different tire size (width or height) means different pressure also, if you stick to stock size use this pressures, the closer the better, try to get Load factor of 95 or above, the closer the better, and speed rating of W or above, the Higher the better.
Luis
Monterrey, Mexico
2007 TL Base, Alabaster Silver, 18" A-SPEC Wheels, A-SPEC body kit.
Luis
Monterrey, Mexico
Luis
Monterrey, Mexico
obviously the tires that we buy have a maximum PSI on the tire, but quite obviously we shouldn't be running around with 50-something PSI.
my question is where is the most reliable and accurate resource to obtain the correct tire pressure when not following the manufacturer's recommended tire size?
rockvilleTL
Sep 19, 2015 04:44 PM
nuldabz
Sep 3, 2015 05:49 PM
