A-Spec Availability
A-Spec Availability
Hey guys,
I understand that most of the A-Spec suspensions have been discontinued from what I have read. Are there any that have not been discontinued and are still available retail? I have heard the 05 MT set is the best; is it available and if not how do the available (if any) compare with the '05 MT suspension kit?
In addition to the suspension kits I'm interested in the ebony/satin A-spec rims for an 05-06 (Don't need the '04 gunmetals, and know for sure they are discontinued) but can't really seem to find them. Whats the word on them being available in the retail setting?
Thanks guys and sorry if I didnt search as much as I should have.
Thanks for the quick response, I haven't personally checked with my dealer, but have checked around on the online store via acura's website and haven't found anything for wither item, same situation with Delray Acura's site. Special order item only I guess?
Thanks again for the responses everyone
the MT susp will drop the front more but only because the AT engine weighs more. so it's acheiving that extra drop by weighing down the springs/shocks by more than they were designed for. it will not give you better performance, worse actually. if you like the look tho, go for it.
Acura is required to keep parts for I believe 8 years after production, so I'm guessing 2014 is maybe when we may see it dwindle down a bit. But knowing honda, I doubt they'll cut down on production of it until the very end
This is some pretty useful info as well. This apply to A-Spec as well? Otherwise how were they able to discontinue the 04 Gunmetal A-Spec rims?
FYI....the part number listed on ebay is the AT type S (older version). it will leave your non-S sitting higher in the front since the S is heavier, regardless of transmission type. 201A is the AT non type S (older version), according to my info.
i checked with my friendly acura parts guy and these #'s are correct. i found this super useful when i stumbled upon it another thread.
Part Number: 08W60SEP200B
SPORT SUSPNSN KIT-MT Type-S
Part Number: 08W60SEP200C
SPORT SUSPNSN KIT-AT Type-S
Part Number: 08W60SEP200A
MT KITSPTS SUSPNION Type-S older version
SUSPENSION A-SPEC Type-S older version
Part Number: 08W60SEP201A
SUSPENSION, A-SPEC Non Type-S older version
Part Number: 08W60SEP201B
SPORT SUSPNS. KIT-MT Non Type-S
Part Number: 08W60SEP201C
SPORT SUSPNS. KIT-AT Non Type-S
If you have the choice and you want the extra drop, no worries in doing the 6mt kit with an auto. But in reality I think the difference is 0" to 1/4".
That explains it! Thanks! Guess I will be going for the AT susp at some point, especially if I can get it as cheap as that ebay link.
08_UA7_Gr33k
02-11-2016 02:17 PM
4drviper
09-23-2015 07:42 PM
