Spacer Question
Spacer Question
I am running stock rims with 255 45 17 tires with a mild drop. I was told I need 10mm spacera in front and 15mm spacers in the rear. I wanted to get h&r spacers but it apears that they dont make a 10mm spacer for the tl. Can any one recommend a comparable 10mm spacer. Thanks.
There have been members that installed extended studs without removing the assembly. I believe they cut the backing plate, slightly shaved the knuckle assembly, and maybe even ground the head of the stud slightly.
justnspace (06-07-2017)
I don't think he bought that to be clear something but rather than just to have flush looks. He clearly said he's running stock wheels ( Base or S doesn't matter). But again, the moment you jacked your car up and measure it that's when you enjoy. Anyways, I hope those spacers work out for you buddy.
