should i get 18x7 or 18x8?
im thinking of buying oz superleggars and i was wondering which size i should get....the offsets are 45...do you think i could manage the 18x8 without rubbing...i plan on going with competechs...also...what size tire do you think i shouold go with both of them
I had the same wheels before on 18x7, +45 and 225/40 tires, no rubbing. If you consider brake upgrades like Brembo, you may need 18x8, but you probably will need to cut the rear tabs.
i have the 18x8 with no rubbing on a stock drop....going to do an h&R sport in a few weeks.
Currently running 215's on em bridgestone potenza
They are great wheels....
Don't do 8's..stick to 7". I had 17X8's(45 offset) with 235/45's on comptech drop, they rubbed in back(cured though by cutting the tabs), and rubbed in front in the inner fenderwell..
Ed
Ed
njtls....I can't tell you if you'll rub or not, depends on the size and brand of tire, but I will tell you this, I wouldn't get a wider wheel if you have a choice, if you plan to run a narrow tire. I'd run at least a 225mm tire on an 8 inch wide wheel.
Originally posted by Bangin'tl
what do you guys mean when you say cut the tabs? what tabs are they exactly? sorry for the dumbass question?
mrkingstonvi
02-22-2016 01:53 PM
Inspire08
10-30-2015 04:00 PM
