Should I change anything else while I'm under
Hey what's up y'all I'm going to replace my struts and tires soon is there anything else worth changing while I'm under the car like bushings or anything like that LCA bushings? I'm also running progress rsb with stock endlinks thanks upperclassmen
buy endlinks.
When removing the rear struts the manual states to remove the endlinks.
An alternative is to remove the bolts that holds down the rear sway bar which will give you some extra room to pull the strut out
BUT,.
I highly suggest removing the endlinks and buying new ones because you may need to do a hack job to remove front or rear, or even both.
BUT,.
mada51589
Jan 9, 2025 04:40 PM
vpasla1
Sep 17, 2016 07:24 PM
sputik
Sep 7, 2015 01:40 PM
