Shaking regardless of speed?
Started feeling some shaking (intense) at every speed. when hitting the brakes, sounds like "thunk thunk thunk". I know I need to replace a control arm so is it even worth changing a tire? and if so, which? Sorry for the quick randomness, will explain more later, trying to get ish done.
Could be any or all of the following.
Warped brake rotors
Broken engine / trans mounts
Bad axles
Bad suspension parts
I had a very bad vibration from 20 mph and up. Changed tires. Got a little better. Changed axles, huge difference. I still have a slight vibration. Next I'll change the front and rear shocks and springs, sway bar links and bushings. Any other rubber I can change.
Warped brake rotors
Bad axles
Sometimes. I still have a bad upper trans mount I need to change. I replaced the front and side engine mounts . That made a difference as well but I used cheap eBay mounts. I think they are crap. I'll change them to oem in the future
EGR valve maybe? My car started shaking violently long ago for me while driving and was worse when at a stop light. The EGR valve needed cleaning.
Ian.van
2G TSX Problems & Fixes
06-30-2020 11:58 AM
duckengine
02-18-2019 12:53 PM
GK83
09-13-2014 12:48 AM
