Semi aggressive looking wheels
Old Jun 6, 2014 | 12:00 PM
Bswain321's Avatar
Looking to buy a set of 18's. Wanted an aggressive stance but didn't want to run crazy camber. Was thinking 10-10.5" rear wheel width. Thoughts for offset numbers
Old Jun 6, 2014 | 12:22 PM
flyromeo3's Avatar
Im sure with even a 10in width, you may need to decrease the camber a tad in the rear.
Of course, someone more knowledgeable will chime in and give a more accurate answer.
Old Jun 6, 2014 | 03:14 PM
Bswain321's Avatar
I'm ok with a little camber just done need more then 2 hopefully
Old Jun 6, 2014 | 04:18 PM
RoyalRandy's Avatar
I'm running 11+20 in the rears with -4.5 camber. I think If you run 10 or 10.5 at +20 or around there, you'll be good!
Old Jun 6, 2014 | 06:01 PM
Bswain321's Avatar
I kinda see your pics. Do you have an of the rear from the back? And what size front wheels are you running?
Old Jun 9, 2014 | 08:28 AM
CLtotheTL32's Avatar
You want to run wheels that are 2-2.5" wider than stock but don't want crazy camber?
What suspension are you on? What is the distance from the ground to the middle of your fender?
Old Jun 9, 2014 | 08:19 PM
Bswain321's Avatar
Well my fenders are rolled and may stretch the quarters
I am on the HT SPEC 2 coilovers Not sure of the distance now but I will raise my car. I'm slammed on stock wheels now but know with wheels I will have to raise up a bit whichh I'm ok with
Old Jun 9, 2014 | 08:36 PM
ATLS_666's Avatar
3 2 GONE
To be flush and withing oe spec, for 10" you should be looking at no less than 40
Old Jun 19, 2014 | 03:58 PM
markp6mttl's Avatar
I'm almost certain that a +40 offset 10" wheel will contact the coilover in the rear. I'm on 9.5 +40's and I have about 5mm or so between the inside lip of my wheel and the height adjustment collar on my Tein Street Flex coils. +40 would give you a shot at being able to not have to pull the fenders (just a roll) or run crazy camber, though. I think something like an 18x10 +38 RPF1 may work perfect in the rear. I think 35-38 would be ideal. Tire size??? 265's may be too meaty and rub a lot. 255/35's are a little short, but would probably work well on this setup and look amazing with minimal stretch.
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
KB1_EJ6
Nov 13, 2016 09:51 PM
PortlandRL
Sep 14, 2015 12:01 PM
devinv1994
Sep 3, 2015 01:40 AM
