Say bar from 17mm -> 20mm instead of 22
Old 03-10-2005 | 12:10 AM
RSA_Secure's Avatar
FIGHTING ILLINI
I know many of you guys have installed comptech 22mm rear sawy bar. I have an AT and was thinking that 17mm to 22mm might be too big a jump and wanted to try out the 6MT's 20mm sway bar. Has anyone done this? Plase advise....is this a good idea?
Old 03-10-2005 | 12:43 AM
rets's Avatar
Moderator Alumnus
22 seems good though...
but, maybe you could get someone's 6MT swaybar... if so, post info in Black market...
Old 03-10-2005 | 01:01 AM
RSA_Secure's Avatar
FIGHTING ILLINI
Not sure if I want to do this....right now just looking for opinions.
Old 03-10-2005 | 01:22 AM
AcuraTLSFan's Avatar
Registered Member
I don't see how it can hurt by going 22 over 20? I bought the Neuspeed 25mm one before they discontiuned it.
The rear doesn't kick out as much around the turns, ride is not compromised too much.
Old 03-10-2005 | 02:23 AM
Contivity's Avatar
Maybe those that have changed from 20 mm to 22mm wants to sell it to you?
Old 03-10-2005 | 12:13 PM
Lore's Avatar
CEO, Team Anthracite
The ride from switching to the 22mm is not compromised at all! It only helps in handling because the sway bar holds the suspension together, causing one end to "lose" traction in sharper turns, allowing you to get your car around the bend faster.
Old 03-10-2005 | 01:41 PM
Contivity's Avatar
does it matter to install A-Spec before or after the swaybar?
Old 03-11-2005 | 12:20 AM
RSA_Secure's Avatar
FIGHTING ILLINI
"lose traction" isnt that bad....
Old 03-11-2005 | 12:52 AM
Lore's Avatar
Yes, it can be bad - hence the increased possibility that you'll swing the rear end around. However, the car still has a pretty large amount of understeer due to its FWD platform and front sway bar that the thicker rear sway bar essentially balances it out.
Old 03-11-2005 | 01:39 AM
dsc888's Avatar
Lore is absolutely right. The TL will plow like a pig when pushed due to it's FWD characteristics. The CT bar still allows it to plow but much less. Trust me, I have pushed my TL to about 8/10s and it's still very stable. In fact, the 22mm bar should in theory make your car handle better in terms of neutality as compared to a factory 6MT TL. But do what you feel is right. I have the Comptech bar and I love it each and everyday. Plenty of folks here seem to agree. Good luck and keep us posted.
dsc888
Old 03-11-2005 | 02:01 AM
RSA_Secure's Avatar
FIGHTING ILLINI
dsc888
Made up my mind....now searching for a good deal for comptech sway bar, possibly on ebay...thanks eveyone for the suggestions
Old 03-11-2005 | 09:03 AM
wakattack's Avatar
I had the same thoughts, but figured if people were upgrading to the 22mm in the first place. Then why do half the job, the CT is only about $50 more than a used bar. For the amount of years/miles you plan on driving the car, It was a no brainer, at least for me anyway.
If you are a real tight wad. You can remove it when you sell the car, and recoop
another $50 I bet. Provided you keep your original.
Old 03-11-2005 | 12:20 PM
Lore's Avatar
Hey - give Falconi a call and ask for Scott. He'll sell you the bar cheap and you won't have to pay tax
You can tell him Kenneth sent ya if you'd like. I need to get on his good side again...
Old 03-13-2005 | 11:56 PM
hondasaurus's Avatar
Review of Comptech Sway Bar 22MM vs. 6MT 20MM
I finished doing the install a couple of hours ago. The install took about 1hr at most.
There is a noticeable difference from driving with the stock 20MM and that of the 22MM. There is less body roll and definitely the turns are tighter. On the "S" turns, the car feels more controlled and I was able to accelerate out of the turns so much faster than before.
I give this mod an A+ and a definite must have.
My current suspension setup is now TEIN BASIC, SPC Camber F/R, and Comptech Sway.
I purchased the sway bar on ebay from Acura Escondido. Best price and fastest shipping.
Old 03-14-2005 | 10:00 AM
DMZ's Avatar
DMZ
Head a da Family
Thumbs up
I agree with you 100% !!
Well said hondasaurus .
Old 03-16-2005 | 01:05 AM
RSA_Secure's Avatar
FIGHTING ILLINI
Finally bought the Comptech sway bar from ebay for $100 shipped.
Old 03-16-2005 | 01:27 AM
rets's Avatar
Moderator Alumnus
That's awesome...
Old 03-16-2005 | 11:52 AM
Lore's Avatar
Hey dude,
I thought you snagged it from Scott directly?
Bet you can't wait to install it. It'll make a huge difference.
Old 03-16-2005 | 01:24 PM
RSA_Secure's Avatar
FIGHTING ILLINI
Hey dude,
I talked to him over the phone and told him that I would get it from their ebay store. It saved me some paper work....like faxing credit card stuff...and talked to him after that too, coz for some reason shipping showed up in the final price (and it was supposed to be free shipping).
Yeah, cant wait to put it on (once it comes). Lore are u coming to the April 16th bay area meet?
Old 03-16-2005 | 01:54 PM
Lore's Avatar
I can't... I have a class that morning. Really wanted too as well... to show off my A-Spec suspension when I get it installed this weekend.
Old 03-17-2005 | 05:14 PM
sparky57's Avatar
Increasing the size of the rear sway reduces understeer. If you find it too much, then you can always bias the tire pressures to the rear to offset the effect.
Conversely, you can duplicate some of the larger sway bars effect by increasing the front tire pressure relative to the rear. The stock settings for the MT are 35 front / 32 rear.
rw
Old 03-17-2005 | 05:27 PM
rets's Avatar
Moderator Alumnus
rw
Well said...
Old 03-17-2005 | 06:35 PM
SnappyPappy's Avatar
I too am considering installing a large sway bar. This car is just too skittish as is. A couple of questions:
a. What is the diameter of the stock rear S-bar?
b. What is the recommended up grade size, keeping in mind a compromise between ride and handling.
c. How many of you guys install your own? Does it involve removing anything other than the original S-bar? Or is it recommended to have a garage do the job?
d. Is there any re-alignment (camber/castor) of the rear suspension necessary?
e. What is a good price to pay? Comptech seems to be a name mention on the forum.
Anyone have any answers would be appreciated - I'm flying blind here. thanks
Old 03-17-2005 | 08:52 PM
Hawhyen51's Avatar
A. Stock ASB: 6MT - 20mm and 5AT - 17mm. The CT ASB is 22mm.
B. No compromise on ride, decrease bodyroll
C. DIY - Do a search for it and save some cash. Not that difficult.
D. Alignment not necessary
E. Previously mentioned in posts; Acura Escondido and Falconi's (LV) or check EBay for best prices.
Old 03-18-2005 | 01:38 AM
RSA_Secure's Avatar
FIGHTING ILLINI
I bought mine from Falconi Acura LV. I got it for $100 total (incl. shipping)...u can call them at....866-418-5442.
Here is an excellent thread on installation:
https://acurazine.com/forums/ramblings-12/avi-movie-help-110867/
Old 03-18-2005 | 04:52 AM
Thanks much. I did some more searching here and pretty much came to your conclusions. Sounds like a no brainer upgrade. Makes you kind of wonder why Acura didn't do this in the first place. Perhaps just to sell the A-spec kit? Or to soften the ride just a bit. (Although everyone keeps saying it doesn't compromise the ride any.) But then young butts are less senstive than my older butt.
Old 04-15-2005 | 09:36 AM
265 ssi's Avatar
320 sc
does anybody know what the auto's stock front bar is ? the 6sp is 27.2 just trying to see if it is worth it to change as I have ordered comptech rear bar
Old 04-15-2005 | 10:43 AM
Hawhyen51's Avatar
Front Stabilizer bar is 25.4 x 4.5 mm, the front tower bar is 45 mm.
Old 04-25-2005 | 01:07 AM
jmichaelp's Avatar
Are there rear sway bars > 22mm available for the 6MT? Wouldn't a slightly larger bar be better for this car??
Old 04-25-2005 | 09:51 AM
Hawhyen51's Avatar
Not at this time and not from CT.
tsx_boy
12-13-2019 09:33 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 09:09 AM
hashbrown
09-29-2015 01:13 PM
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 11:39 AM
Quick Reply: Say bar from 17mm -> 20mm instead of 22
