s2000 16' mag with mt slick !!
s2000 rear wheel to fit 26x10,5x16 mt slick !!
need grinding 1 inch inside de wheel and 1 1/4 spacer approx..
pics http://s757.photobucket.com/albums/x...%20mt%20slick/
makes sense then... i think you should try a few drags on stock rims and tires then a few with the slicks average out the two and see if slicks on a TL-S are really that much of an improvement over stock rubber.. that would be interesting to know
yea it would be nice to do 5 runs on each and average them out to see what the improvement really is from stock to slicks on a TL... A TL doesnt have crazy torque where you are spinning tires at the line like if you had a high torque V8 RWD where rear slicks make a lot of sense. Once you get off the line slicks kinda lose there advantage... I couldn't imagine slicks giving him that much of an advantage over stock on a 1/4 mile maybe .1 to .2 of a second?
thx improuvement is pretty good with street falken azenis rt-615
best run is 14.3 with 101 mph !!! 60 feet 2,6 very bad with whhel hop ....
now just 2 run best is 13,77 with same 101 mph so 60 feet 2,1. !!!! lauch 2500 rpm !! next years try more hard lauch with backup axel !!
Nice! 6/10ths reduction in the 1/4. You're quicker than a supercharged TL on street tire.
Have you run into any wheelspin or can you bring the launch rpm up a bit? I would think you could do 5,000rpm without it spinning much for a 13.5 1/4.
There's no reason you shouldn't be able to get a 1.8 or better 60' out of those. What tire pressures are you running? Those seem to like it in the high teens/bottom 20s.
