Rubbing
Old Feb 10, 2002 | 08:10 PM
bmikell's Avatar
Rubbing
I JUST PUT A SET OF NEW RIMS AND TIRES
RIMS +45 OFFSET/ 17INCH
TIRES 235 45 17
IT IS RUBBING IN THE REAR.
CAN SOMEONE HELP?
Old Feb 10, 2002 | 08:44 PM
bigman's Avatar
'Big Daddy Diggler'
you should have gotten 235/40/17 or you can roll the fenders.
Old Feb 10, 2002 | 09:38 PM
StanMan's Avatar
figure out what part of the rear is rubbing...more than likely, the bumper tab is doing the most rubbing. you can worry about the metal fender lip later... plus how wide are your rims? you might have over did it with the 235s.
Old Feb 11, 2002 | 12:57 AM
Lawaia's Avatar
Moderator Alumnus
Depending on the offset I think your problem is with the plastic bumper tab. Trim that off and you should be ok. Accommodating a .6" inboard/outboard increase should be no problem with the correct offset.
Old Feb 11, 2002 | 08:50 PM
bmikell's Avatar
RIMS ARE 17 X 7
WHAT IS THE BUMPER TAB?
AND CAN I FIX IT ARE CUT IT?
Old Feb 12, 2002 | 12:34 AM
ssk0771's Avatar
Type SSS
Originally posted by bmikell
RIMS ARE 17 X 7
Bumper Tab is part of you bumper that goes to you rear fender well. You should be able to cut that off pretty easy. Just look the area that is rubbing. Thats probably Bumper Tab.
Old Feb 12, 2002 | 03:01 AM
SinnedTL's Avatar
Ain't No Other...
with a 7 inch width rim and 45 offset and your 235/45/17 tires, it is definetly your bumper tab that is rubbing not your rear metal fenders, so dont worry about it too much, just cut the bumper tab off where the bumper meets the rear fender, and it will take care of it...
08KBP_VA
Oct 22, 2019 01:55 PM
Jul 16, 2017 07:33 AM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
Tribalheads
Sep 29, 2015 03:24 PM
