Which RSB to go with?
BANNED
07 tl-s, want to get a RSB.
there's a comptech RSB that i can get http://www.racingambitions.com/Produ...torysingle=YES
then there's excelarate's progress RSB http://store.excelerateperformance.c.../i-225595.aspx
i can get the comptech for around $70 shipped, or i can get the progress for $135 plus shipping.
i know the progress is 24mm and the comptech is 22mm, i believe they are both adjustable.
anything else i'm missing? anyone else have any opinions on this? what should i go with and why? how do these differ from the type-s stock bar?
thanks everyone
thanks everyone
BANNED
$70 is $70 no matter how you look at it, just trying to save money obviously.
I think with whatever route you go, you'll get the improvement that you're looking for.
Im looking for some of I hate cars articles on rear sway bars....
From this thread:
https://acurazine.com/forums/showthr...=rear+sway+bar
All '04-'06 ATs had the same swaybars, even an original a-spec.
Autos got a 25mm hollow bar. 17mm rear.
Manuals got a 27mm hollow bar. 19 or 20mm rear.
TL-S got a 27mm solid bar. 20mm rear.
I have the H&R solid 28mm bar, stiffer than it's size would indicate likely due to the material used. It's in the soft setting and I could not imagine how stiff it would be in the firm setting. It's already too much bar for the Progress rear in the firm setting.
BANNED
hmm...wonder how much difference 2mm will make, depending on the construction of the type-s rear n the comptech rear.
is 2mm worth $70?
is 2mm worth $70?
AZ Community Team
Received 7,770 Likes
I'm not sure if the Comptech is adjustable or not; I'm thinking not.
Tough choice. At a similar price/smaller differnce, it'd be Progress no question.
I'm a fan of the PRogress bar, but only because that's what I've got. But IF you do get most of the gain and save $70 .... .
I assume the Comptech bar is used; make sure it comes with good bushings, good brackets and all the hardware. If you have to buy that, you'll end up at more like $100.
AZ Community Team
BANNED
true...
i'll stop pinching pennies so hard n just go with the progress. i like the adjustability, 24mm, and rave reviews i've read.
thanks for your input guys.
AZ Community Team
I think you can set the Progress Bar up for 3 settings. Soft, medium and firm (or whatever you want to call them).
To get "medium", on one side use the "long/soft" hole and on the other use the "short/firm" hole. I'm sure I've read Josh (Excellerate) post this - but you can double check with him to make sure I'm not giving bad info.
BANNED
np will do.
my progress thread in the photo section needs to be updated badly, i have been doing stuff each weekend and have some updates to that thread that i'll end up adding in a few weeks once everything is done.
then i plan on relaxing thru the fall n winter n saving up for coilovers for spring.
**EDIT: really good to know bearcat, thanks!**
Last edited by SharksBreath; 09-30-2010 at 09:51 AM. Reason: bearcats impeccable timing
FYI - I'm running the Comptech and it made a huge difference in the handling of my '06...just sayin'.
BANNED
AZ Community Team
I have a progress RSB on and I definitely notice a big difference around turns. In normal driving it's not that noticeable but if you start pushing it in curves you'll be surprised at how big a difference it made.
Just an FYI, you may want to upgrade your endlinks too. I replaced mine with the thicker Moog endlinks at the same time. I got them for around $50 for both on amazon.
edit: oh and I have mine on the firmer setting.
2mm is a lot in swaybar stiffness. It is noticable. I did the math a long time ago but going from my 17mm to the 24mm was in the neighborhood of 500% stiffer.
Going from the front hollow 25mm to the solid 28mm was an even larger difference. I don't know that I'm sold on it. There's a very steep entrance to the parking lot at work and since I've installed the large front bar, my ABS goes off every time I enter because it tries to lift the inside tire off the ground.
Either bar will work fine with the type S. I wish I would've measured the distance from the holes to the mounting brackets on my Progress bar. I'm not sure if the soft setting or firm setting gives you the true 24mm. For all I know, the soft setting may position the end links farther from the mounting brackets giving you the equivalent of a 22-23mm bar and the firm setting gives you the true 24mm equivalent.
BANNED
^thanks, IHC.
so either one is appropriate? you say 2mm is a huge difference, maybe i wouldn't even put it at the 24mm, being that it could be too stiff for my liking.
in which case, the 22mm comptech would probably be perfect and i'd save 70$ in the process.
although i'd hate to get the comptech, install it, and wish it was stiffer but not be able to do anything about it.
i'll have to think about this over the next few days.
Chapter Leader (Central Florida)
When I was checking out HT's newest suspension I saw an option to add a 25mm HT-Spec bar.... just saying, maybe something new is coming out and will provide yet another option.
I gotta get something other then my stock... Good Grief guys!!! my son's sc300 stayed with me around a quiet cloverleaf the other night....
Of course he's r-wheel drive, lowered on k-sports.. tired 2jz as well....
Note: I have 35 years of racing under my belt.... It was not bad driving on my part. Same tires on both cars
Good thread and alot of good info! Owning a type-s myself, I would personally spend the extra $70 knowing it has adjustable settings...guess its kinda like coilovers over just springs....$300 or $1K+.....to a certain extent...lol
BTW - Bearcat94 has the Best. Sigline. Ever.
I'd say dish out the extra $70 and get the Progress. What's $70 on a $40k+ car? I'm definitely going for the Progress bar at the same time as the Tein SS and Ingals camber kit. (Save on the shipping, not the parts )
It's not about price, it's about which one will work best with your combo.
Had mine on since December 2006, no problems.
TSXdriver19
06-06-2008 07:55 PM
captain
09-29-2004 04:02 PM
