Routine Maintenance
Routine Maintenance
My 08 TL has about 25k miles on it and during routine service the dealer recommended 4 wheel tire alignment, and flush and change transmission and brake fluids, the two latter were about 180 bucks each. I said no that sounds too much how often should brake and tranny need to be done.
I don't think you need the brake fluid or the tranny fluid changed yet. Especially not for $180 EACH! Wow lol. Tranny fluid change wouldn't hurt though. Better to be safe than sorry. If at all possible try and see if you can do the tranny fluid 3x3 change on your own. There are some DIY writeups around here.
Registered but harmless
Received 1,106 Likes
Transmission fluid- it's the "3" code in the MID MM.
However, most people do at least a 3x3 drain-and-fill every 60K miles, while some are more comfortable with a 3 x 3 every 30K, and others do a 1 x 3 every other oil change.
Welcome to AZ.
AZ Community Team
Received 7,770 Likes
Find an honest dealer. Or some other reliable service.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
