Right front tire PSI
Is anyone else having problems with air pressure in the right front tire? I've read a few issues on this board. The pressure seems to fluctuate from 32-26 psi.
Doug
06 TL auto
Doug
06 TL auto
You mean to say the actual pressure goes from 32 to 26 then back to 32 then 26 again etc etc .. or are you saying its doing it on the TPMS readout?
maybe a bad stem or it could be the worst, bent rim
Originally Posted by rooster67
I'll air it back up to 32psi, then the TPMS will show it to be around 26psi in about a week or so. Tire was checked with no leaks..
Doug
Doug
To check the tire for leaks did they take the rim off the car and submerge it in a tank? Running water over it may not show the leak and if it was checked withthe valve cap on it might hide a valve stem leak. You can check the valve in the stem stem yourself by taking the cap off and putting a nit of spit or soapy water on it.
TLDude876
12-28-2016 03:18 PM
nuldabz
09-03-2015 05:49 PM
