My son's '05 TL (65k miles) has recently developed a noticeable clunk-like noise when encountering minor potholes and bumps in the road at normal town speeds, 25~35 mph. It doesn't seem noticeable at walk speed. The dealer couldn't reproduce it in the shop and so in the interest of embellishing the service department's receivables, suggested a shotgun approach of some $1200 worth of non-descript suspension work & a "complimentary" realignment. Feeling that they're only guessing at the problem, we temporarily declined.
Tires & brakes are new and this noise preceeds tire & brake replacement. You can hear it inside the cabin though it's not loud. There seems to be no driveability or handling issue. Alignment has been checked and is good. No accident history.
Anyone with any ideas what this could be?
Thanks!
Thanks!
3rd Gear
I am having that exact problem. Mine is an 05 as well. If you figure anything out please let me know. I talked to a couple guys who think it may be a bad strut. I'm not for sure yet.
e30cabrio
LFG RANGERS!!!!!!!!!!!
close
- Join DateOct 2004
- LocationEarth
iTrader Positive Feedback100
iTrader Feedback Score(6)
Liked:2,663 Times in 1,902 Posts
My 01 CLS has this, I am pretty sure it is radius rod bushings. I am about to replace them so I'll be able to report if it clears it up.
Thanks. Please do let us know if there's any improvement. The dealership wanting to replace some suspension parts (to the tune of $1200+) couldn't guarantee that this was what we needed, but said that two of their line techs agreed this was where to start. I might have let them proceed had they been able to reproduce the noise in the shop or by driving around the lot, but $1200 is a lot of gelt for guesswork. The size of "bump" it takes to cause the noise at 30 mph would be approx equivalent to running over a piece of 2 x 4 lumber.
It almost sounds like a weak shock or loose caliper but the dealer said it's rare to have to replace shocks before 90k. Nothing is leaking or loose and the brakes were just done (and the noise preceeds the brake job).
e30cabrio
close
- Join DateOct 2004
- LocationEarth
Mine does it (sporadically) when coming to a stop, when going over a speed bump (slowly) or seemingly for no reason.
My entire suspension (except radius rod bushings) is under 10k. I have an appointment to take the car in next Monday, hopefully I'll get it back by Wednesday and I'll report as soon as I have info.
e30cabrio
close
- Join DateOct 2004
- LocationEarth
"Like None Other"
i had this problem before and sure enough, it was attributed to my endlinks! my left one was pretty destroyed. so i would tart there. if not that, check the motor mounts....my$.02
Retired!!! ON TOP!!!
yes SIR!!! it's the sway bar endlinks that need replacements... Problem SOLVED!!!
/thread
/thread
e30cabrio
close
- Join DateOct 2004
- LocationEarth
These are much bigger (stronger) then stock, I have them on my car & they are great. They are front/rear & side specific.
http://www.amazon.com/gp/product/B00..._ya_oh_product
# 1 of: Moog Chassis K90340 Suspension and Alignment
Sold by: Amazon.com, LLC
# 1 of: Moog Chassis K90343 Suspension and Alignment
# 1 of: Moog Chassis K90341 Suspension and Alignment
# 1 of: Moog Chassis K90342 Suspension and Alignment
Quote:
/thread
Thanks!Originally Posted by rodneyc77
yes SIR!!! it's the sway bar endlinks that need replacements... Problem SOLVED!!! /thread
Any guess as to cost to have the dealer perform the repair?
e30cabrio
close
- Join DateOct 2004
- LocationEarth
They are two nuts each. It is an easy job.
Quote:
Sorry, In non-gearhead speak?Originally Posted by e30cabrio
What's involved? raising the car? Removing (?) for access (wheels, etc?)
approx parts cost? Any special tools?
e30cabrio
close
- Join DateOct 2004
- LocationEarth
About 80.00.
Those are the parts.
You pick up the car, no need to remove the tires. You need allen wrenches and sockets. a big vicegrip helps but is not mandatory.
I hate cars
close
- Join DateMar 2006
- LocationBakersfield
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,818 Times in 1,287 Posts
Quote:
Same here. I had the annoying problem mostly over small bumps. Mine wasn't the end links, it was the swaybar bushings but still swaybar related. Originally Posted by djbonsu
FWIW, it seems when there is a lot of noise over little bumps it's usually swaybar related in these cars.
I still have the urethane front swaybar bushings for the auto trans (25mm) with less than 100 miles on them if anyone wants them very cheap. I removed them only because I installed the large 28mm H&R bar.
How bad were those endlinks when you pulled them out? Mine are nearly frozen, they didn't seem to have any play in them but I'm getting some of the clunk back again and I'm suspecting the large 28mm bar is killing the stock links.
e30cabrio
close
- Join DateOct 2004
- LocationEarth
Mine were pretty trashed and the Moog that I posted are much much burlier.
I hate cars
close
- Join DateMar 2006
Quote:
When you say trashed, did they have a bunch of play in them? I'm sure the solid 28mm bar I have installed is not helping them.Originally Posted by e30cabrio
e30cabrio
close
- Join DateOct 2004
- LocationEarth
There was some play.
I have the 27mm Neuspeed in front and 23mm Comptech in back, these work great.
You should check the part numbers those are for gen2 TL/CL don't know if there are different ones for third gens.
*edit*
Looks like they are the same:
Acura
CL
2001-2003
REAR SUSPENSION~RIGHT
Acura
TL
1999-2003
Acura
TL
1999-2006
Acura
TL
2007
Acura
TSX
2004-2005
Acura
TSX
2004-2007
Acura
TSX
2008
Not Mfr Data - Derived from OE - Match to Original~REAR SUSPENSION~RIGHT~OE: 51320SEAE01, 51321SEAE01, 52320SDR003, 52321SDR003
Honda
Accord
1998-2002
Honda
Accord
1998-2006
Honda
Accord
1998-2007
*edit*
Acura
CL
2001-2003
Acura
TL
1999-2003
Acura
TL
1999-2006
Acura
TL
2007
Acura
TSX
2004-2005
Acura
TSX
2004-2007
Acura
TSX
2008
Honda
Accord
1998-2002
Honda
Accord
1998-2006
Honda
Accord
1998-2007
"Like None Other"
the endlink was pretty damn loose! i could simulate the play in them using my hands!! i was thinking of upgrading to the TL-S sway far up front to help out the oversteer i have from being slightly raked but i was thinking ill need to upgrade the endlinks as well too. how are urs holding up with H&R sway bar?Originally Posted by I hate cars
Same here. I had the annoying problem mostly over small bumps. Mine wasn't the end links, it was the swaybar bushings but still swaybar related. FWIW, it seems when there is a lot of noise over little bumps it's usually swaybar related in these cars.
JTS97Z28
close
- Join DateSep 2007
- LocationPlainfield, IL
- Age45
iTrader Feedback Score(4)
Liked:949 Times in 652 Posts
WOw this is so weird I was actually going to make a post about this EXACT problem I am experiencing on my 07 Type S. Since day one I noticed what sounded like a "loose" front right suspension. You wouild hit a bump and it just felt sloppy. No handling or alignment issues or previous accidents. Glad I stumbl;ed across this thread im gonna go remove my front right wheel and see whatsup.
James
James
JTS97Z28
close
- Join DateSep 2007
- Age45
Well I just pulled the front right wheel off and inspected everything cant find anything loose. Hummmm
James
James
e30cabrio
close
- Join DateOct 2004
- LocationEarth
Quote:
James
I picked mine up at least five times. Nothing loose or looking like it was not the way it should be. Originally Posted by JTS97Z28
Well I just pulled the front right wheel off and inspected everything cant find anything loose. HummmmJames
I have replaced everything but the radius rods & bearings so by a process of elimination the bearings have to be the culprit.
The car goes in on Monday, I hope the noise is gone after I get it back.
I hate cars
close
- Join DateMar 2006
Quote:
So far so good. I'm getting a very slight clunk just like before but barely noticable. Last time this happened it was the swaybar bushing bolts. Going to check that first. If it turns out it's the endlinks I'll definately let you know.Originally Posted by djbonsu
You'll love the TL-S front bar especially in the higher speed turns.
JTS97Z28
close
- Join DateSep 2007
- Age45
I dont know what the radius rod bearings are. Can anyone give me a picture or explain it to me. Originally Posted by e30cabrio
I picked mine up at least five times. Nothing loose or looking like it was not the way it should be. I have replaced everything but the radius rods & bearings so by a process of elimination the bearings have to be the culprit.
Thanks,
James
"Like None Other"
So far so good. I'm getting a very slight clunk just like before but barely noticable. Last time this happened it was the swaybar bushing bolts. Going to check that first. If it turns out it's the endlinks I'll definately let you know.You'll love the TL-S front bar especially in the higher speed turns.
yea, i still get a "HUSHED" clunk every now and then and i think im just gonna attribute it to the TLs front suspension. once i get the new sway bar, bushings and endlinks, ill check for noises again. my bro in-laws 01 CL does the same thing although i suspect his endlinks are bad. havent checked his out yet.
8th Gear
I have the very same issues like you guys, but my Endlinks fell tight on my 04 Tl, I've just ordered a set of KYB GR-2's so when I get them in and installed I will surely let all know, It is very annoying and I need to get it gone soon.
I have a slight Endlink pop in the rear but I need to settle the front first.
"Like None Other"
^^^are your shocks worn? Why are you replaceing them? If you are experiencing clunk noises I'm pretty sure the endlinks are going. All it takes is one massive pathole and that endlink will be on its way out. Just wouldn't want you to spend more $$ than you would have to....my $.02
Noob here... just bought an '07 TL. Having a similar sound, but coming from the left rear. The clunk is driving me crazy!
8th Gear
Hey Guys The noise is on the top half of the mount, I believe the noise is traveling but all is tight as far as i went threw all components. When the shock was out of the vehicle I grabbed the ends of it and pushed in and out (no pun Intended) and it made a slight clunk when I tried changing directions only rest was ok.
So thats the only reason for the change just giving it a shot.
Got the KYB's for the front for 124$ on Amazon Just Suspension.
Thanks for the .02$
Thanks for the .02$
