Review COMPTECH Sway Bar
Just had it installed this morning, and all I can say is WOW
. Took the TL to the twisties and I could not feel the pull at all, and the rear end stayed planted to the ground the whole time. The $110.00 was worth every penny.
Originally Posted by VTEC=happiness
THanks for the info...I was convinced to not get the bar, but now I must!
Oooo! Oooo! Me next! Me next!
I'm almost convinced. Does adding the sway bar make the ride harsher? I wouldn't think so, but I want to make sure before I plunk down the bucks for the bar and install.
You can call Comptech or, go to an Acura dealer which is an authorized Comptech vendor. I had mine purchased and installed at Superior Acura (Auth. Comptech dealer) that way if anything does go wrong its still covered underfactory warranty along with they cant blame it on the install because they installed it. It ran $110.00 for the Sway bar, and $90.00 for the install.
im going to acura 101 west tommorrow to schedual my B service as well as a couple warenty issues, and will mention the comptech rear sway bar for my manual. I live 2 min from the canyons and, is a definate must for my driving commute.
Originally Posted by aGenKa
any 6 sp owners make the jump yet?
Originally Posted by qali
ali:
looking at your sig, it doesn't look like you have any other suspension mods (besides the sway bar). Is this true? Adding just a sway make this much of a difference?
Originally Posted by Aegir
Same question here. Doesn't seem like it would be nearly as much of a change on the 6MT. It already comes with an upgraded rear sway bar - 20mm.
It may not be as much of an improvement as on a 5AT, but an improvement nonetheless. I'd do it if I had the stock 6MT bar. Like someone else said, it's only $110. It's pretty easy to install too. I wouldn't suggest paying for installation unless you have no experience with tools. It's literally 9 bolts and 5 hangers. That's it. Piece of cake. Must get all four corners in the air though.
I"m confused. Did you just replace the rear bar? If so, how would this effect the "pull" as you describe it? (maybe I should ask what you mean buy pull - but I assume you mean torque steer).
Originally Posted by ZQQM
Could someone please specify what the dimensions are for the stock 5at and the CompTech bar. I know the 6mt is 20mm. I curious as to how much larger the comptech bar is over stock 6mt.
Sounds like a good upgrade. Just be careful though guys; cars with upgraded sway bars don't give as much warning when they're about to let go as stock. Of course there's VSA to help out, but if the car lets go, I suspect there won't be much warning. Having said that, I'm probably going to get one too, as soon as I pay off my laptop..
Originally Posted by SparkAF
Is it worth adding to a none "A"Spec TL
The A-Spec TL does not come with upgraded sway bars just upgraded shocks and springs. So the A-Spec 5AT has the 17mm rear sway bar, and the A-Spec 6MT has the 20 mm rear sway bar (just as the regular TL).
If you have the 5AT you can definitely feel the difference much more in the turns. The 6MT not so much (I can tell you from first hand experience because I have the Comptech sway installed on my 6MT). You can only feel a change in the most aggressive of cornering, so it is much more subtle than in the 5AT.
So I guess you're saying installing a Comptech Rear Sway Bar on a non-A-Spec 5AT will improve handling
dsc888
Thanks for all the info fellow TLers. I just called the dealer and will have my sway bar soon. I'll be rolling over some of my favorite curvy Georgia roads before and after I get the RSB. I have the non a-spec suspension, 17 inch factory rims.
Originally Posted by captain
Acuravic - where are you having it installed? Are they getting the bar for you? How much for the bar and install?
And Yes, Acura is an authorized vendor/seller of comptech products, they will go to the website and order the part and have it delivered to the dealership.
Originally Posted by lovepo9e
Can anyone take pics?
Here is the link....
http://www.comptechusa.com/store/product411.html
Comptech RSB
I was thinking of installing it myself. Is the TL service manual really needed? If so, can someone scan and post or email the appropriate pages. spara1@cox.net
BTW - I used channel locks to hold the bolt still and scratched it up in the process. Using an allen wrench will make things much easier.
I will scan and send the appropriate pages when I get home, if I can remember :blaze:. Maybe someone else can beat me to it though.
thanks in advance... tizo@cox.net
I installed mine this afternoon ( Had some time off for IVAN). I don't think anyone should pay for this install. It took about one hour and most of that time was spent jacking the car up and getting it on the jackstands.
--I only lifted the rear of the car.
-- I did not remove the cat back exhaust to complete this install.
I seperated the driver's side muffler (two bolts) and then took everything off. I did put some slight scrapes on the new bar by doing it this way but my car isn't going to world of wheels or anything. The car feels alot flatter in turns. It is a nice upgrade, not drastic but definitely worth 110 bucks. There is a 90 degree curve near my house that I can take about 10 mph faster, even with my crappy EL42s.
EVERYONE SHOULD BUY IT.
btw Falkens are next for me.
