Recommend tire size for 19" wheels that can provide a more comfortable ride
Happy Holidays!
I currently have kumho escta 235 35 19. They ride very rough. The side wells are very weak. Any scrape with the sidewalk can cut a piece of the side wall out. I'm looking for a tire size that can provide a more comfortable ride. I don't necessarily need the low profile look. 235 35 is too low. Thanks.
My Garage not
1 Post
Originally Posted by princelybug
Are you running 19x8, or 19x8.5?
If you're running 8" wide wheels, I'd recommend staying with 235/35's.
If you're running 8.5" wide wheels, then 245/35's would be the most I'd go.
LIST/RAMEN/WING MAHSTA 짱
Originally Posted by wasupdog
yup, u can't really get a bigger tire or else the tire will bulge off the side of the rim, u can only go smaller. if u have 8.5" rims get some 245/35's. try falken 452's. they are quiet and offer a good ride.
I've got the Falken 452's and so far i'm pretty big fan, I have like 12,000 miles on them and they look almost brand new, they are starting to get just a little bit louder but still much quieter than any other tire i've ever had, it will probably be your best bet
Happy Holidays!
My wheels are 19x8.5 if that helps.
Sorry let me clarify. I would like to get tires with a wider area of sidewall. So it's the width from where the tire touches the ground to where the tire meets the lip of the rim.
Thanks.
Thanks.
The only way to avoid the "weak sidewall" issue you described is by not curbing the wheel. Any tires, that are made of rubber, won't stand a chance against a concrete curb.
Anyway, if you're riding on 19", it would be difficult to get "comfy" ride. Even if you go with higher profile, like 235/40 R19 or 245/40 R19, you'll still end up with very low sidewall that translates to firm ride.
Check your tire pressure. If you're running too high of tire pressures, you'll also experience rough ride.
Veni, vidi, vici
ok, so the deal is, you really shouldn't change the whole diameter of the wheel, hence bigger rim = smaller tire and vis versa. The reason for this is, once you change the diameter of the wheel, you also change the circumference, which in turn can kinda mess up your speed guage. Right now, I'm running 245/40/19 x 8.5 (Which has really, really, really good comfort and the tires don't look bulgy, and they are falken 452) which 4% larger in circumference , translation: when my speed guage tells me I'm going 60mph, I'm actually going 62 and for every 100 miles my car counts, it actually is off by 4 miles. Some people will tell you not to do that, but IMHO, I change my wheels in the winter to OEM, and I'm not planning on getting rid of this car, so i don't have to worry about lying about the mileage count. Honestly, the ride feels like I'm on factory wheels, the comfort, and everything. Although, I am no speed demon, mainly cus I don't want to mess up my rims, I don't know what the ride is like over 70, but i don't think it's any difference.
When I was riding on 235/35/19, the ride was killing me, and my old rims where getting pounded, since the sidewalls where so thin, but when I made the move to 245/40, incredable difference. BUT DON"T GO HIGHER THEN 245/40/19, then thats WAY to much.
Back from the dead after 2 years.
Those 245/40-19 are huge. They are more than 1.25" larger than the OE tires.
Guess the bottom line is that when you go 19" you're certainly going to notice a deterioration in ride quality. Stick with 245/35-19, or if ride quality is your main concern, stay with 245/45-17, or even a 18" with 245/40-18. You can even get some H rated tires in the 245/40-18 size that will offer a softer ride, but in the 19's no such luck as all ar UHP..
Too Fast TOO FURIOUS
keep in mind that ride comfort is subjective, and suspension plays a role (oem vs aftermarket).
For most comfort, stick with 17s.
For some comfort + some looks, go with 18s.
For less comfort + more looks, go with19s.
For no comfort, go with 20s.
Sidewall = aspect ratio = profile.
That being said, I'm running 225/40/19 on my '03 Accord on the accessory RDX rims and the ride is great!
This would be my next question ... if i were to go to 245 40 19 on a 19x8.5 wheel ... would rubbing occur? that would be the only negative for me. as I dont mind it looking a little truckish if I can get the smooth ride back.
I test fitted a 245/45-18 (which should be similar in size to 245/40-19), and it rubbed like a bitch... The sidewalls were noticeably bigger than the correct aspect ratio. This was on a +30mm offset wheel, so your situation may be different...
Veni, vidi, vici
No rubbing on 245-40-19's, and I am dropped 1.5" all around. Don't get me wrong, if I didn't live in boston and lived in Florida or down south I would def stay with 235/35/19, but god dayum the streets are Horriful in boston, so i had to do what i had to do, I will post pics of my ride today, THEY DO NOT LOOK TRUCKERISH!!!, they only add .5" to the sidewalls, not even noticable. BUT the ride is WAY WAY WAY WAY WAY smoother, and it feels stock, I have S. tech springs, they dropped me 1.5", I thought it would be less, like 1.25" but autoshop guy says it dropped 1.5". NO rubbing. beautiful.
Hey man ... is your car lowered? My understanding is that if the car is not lowered it wont rub lock to lock ... so thats y im just wondering?
Nope.. Stock suspension/height... Like I said, it may have had more to do with the +30mm offset of the wheels... All I know is that it rubbed quite a bit when I turned the wheel.
Being an Acha Bacha in
For those of you going with bigger rims... the best bet would be to upgrade your suspension to an aftermarket one that has dampening control and then set that to softest setting you can tolerate. Another tip is shop for tires that have a soft sidewall since these tires will give you the best ride comfort. However soft side walls diminish handling.
Head a da Family
Also, having been here on AZine for almost 7 years, most of the ride/tire/wheel complaints have been from those with 19 & 20" wheels.
If your looking for a quiet/comfortable ride as your title of this thread suggest, then no ultra high performance tire is going to give you the best in those areas. If you want UHP all seasons that provide the best ride quality/low noise FOR THAT CLASS TIRE, then you'll want either the Michelin Pilot Sport A/S Plus or Pirelli PZero Nero A/S!
Personally, if you want the best ride quality and lowest noise level you'll have to get a all season grand touring tire. I'm not sure about the 19inch size and if these tires come with it but I would recommend the Michelin Primacy MXM4, Bridgestone Turanza Serenity Technology, or Kumho Escta LX Platinum!
Sorry, I calculated the sidewall height using tread width not section width. Correct numbers are 3.32" for the 235/35 19 ( they all have a 9.5" section width ) tires listed below and 3.92 for the 245/40 19 ( have 9.8" section width ) tires except for the Bridgestone which comes out to 3.96 with a 9.9" section width
Im on this situation, buying some 19's and chossing tire and size.
What about this tire Hankook Ventus V12 evo K-110??
http://ventus.hankooktire.com/
Yes, I've heard they are great in those regards as well, but I've been told that they are only meant for spring, summer, and fall. They are not designed for winter weather or ares of the country that get a lot of snow,sleet, or ice! I think they are a dedicated summer tire if I'm not mistaken?
http://www.tirerack.com/tires/survey...ter=19&type=MP
Yeap I have been doing some research on this tires and they seem the way to go. Good tire and is not very expensive versus some TR'1 and dunlop or yokohama.
I wanted to know some feedback from someone that has them on their car.
+1 For 245/35 19.
Just got new wheels last week with that size of tire, and it rides perfectly! No rattles, vibrations or rough "go karty" feel. I was concerned about loss of ride quality, and was surprised at how great it has been!
cammy5
09-04-2015 11:26 PM
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
