Rear toe issues...
Rear toe issues...
Took car to check get alignment before new tires go on. Car is lowered on Tein srings about 1.5" Caster I have set at -1.2* each side on rear. Have adjustable uppers!
The most they can get the rear toe is as follows:
Left .17*
Right.23*
Total .40*
So they said basically the bolt must be seized in there as it's not moving, or maybe it's maxed out??
Anyway do i just replace with stock or should i just an aftermaret control arm?
Which one do I want?
Thanks,
Left .17*
Right.23*
Total .40*
Thanks,
I'd also research those Ingalls you're interested in, quite a few complaints about the bushings used in them and lowered guys were finding themselves constantly out of alignment with those installed.
I'd suggest new control arms, if seized, and you may get it back within spec. Not sure of the stock rear control arm toe range though.
EDIT - Here you go.
Rear toe spec thread:
https://acurazine.com/forums/tires-w...n-rust-929852/
Ingalls Issue:
https://acurazine.com/forums/tires-w...er-kit-846561/
I actually had a set for both sides (Ingalls) but returned them after reading about the related bushing issues...and I'm not lowered.
Maybe it's just me, but with only a 1.5" drop, you shouldn't have any issues getting the toe back into factory specifications. Something's not right...
I agree too, OP should prepare to saw of the rear control arms.
I had the alignment guy come get me to show that the bolt was not only seized, but rounded off. The fine folks that took money from me and supposedly did an alignment a few months prior, failed to mention that detail...go figure.
OP stock > aftermarket rear control arm. I used synthetic, ceramic anti-seize grease in there, a LOT, to ensure they wouldn't seize after I installed them.
Common issue with so much heat from the exhaust as well as winter salt.
![](https://cimg4.ibsrv.net/gimg/acurazine.com-vbulletin/190x355/81mokmnfjkl_sy355__c4a944c5acba1e9633492799af39e9bd2d0d69fe.jpg)
the mechanic was a buddy at the Honda dealer.
He said they were seized and said he could heat them, but probably ruin the bushing.
They didn't charge me anything since they counldnt fix it.
So do you think i should just go oem?
The ingalls supposedly fixed?
Or any other oftermarket brands for the lowers?
OEM - Yes
I'd personally stay away from Ingalls, unless you going for a mad drop. I'm sure a vendor (or two) will chime in and assure these are OK, I'd read the whole threads related to Ingalls before dropping cash on them.
OEM are not expensive, folks go aftermarket when going for those mad drops.
What's your suspension / wheel setup? If it's close to stock no real need to fork money over on aftermarket stuff to compensate for mad drop / +2 wheels.
Abyss Beauty
I had the SPC and Ingalls arms. Ended up getting rid of ingalls arms for oem arms.
My ingalls were 3 years old with badly worn bushings. I've only put 8k miles on the car in 2 years. Rear of car felt like crap due to the shot bushings.
Whenever I aired out, the wheels would stick out towards the rear bumper a bit. With OEM arms they're straight as an arrow !
with the spc arms and only 1.5" of drop, the OEM toe arms (rear control arms) should handle your toe just fine.
I got both control arms, bolts and nuts for $168.xx shipped from acurapartsforless.
Is that better suited for this purpose than just standard white lithium grease? I'll have to check that stuff out...
I think synthetic anti-seize with ceramic is just starting to gain traction in the market. Although this is marketed for "brakes," I also used it on all of my exhaust components to the long tube after the third cat.
Here's the website details:
Specialty Lubricants - Brakes : Permatex® CeramicExtreme Brake PartsLubricant
I bought it on Amazon for about $8.
OEM arms & bolts came in yesterdy.
Jacked up rear end and cut bolts out in 5 mins aside.
OEM arms back in in 15 mins aside.
1 hr project start to finish in garage/driveway.
Got it aligned and all back to spec!
New DWS 06's on this weekend
What blades did you use and how many?
Slpr04UA6 (11-18-2015)
OK, I do have a 7" cut off blade for my Craftsman C3 grinder. Good idea, I'll give it a shot. Is that blade of yours 7" or 8"? Looks like 7"....
Did you have to cut both sides of the bolt?
Yes had to cut the bolt on both sides.
The side closest to front is a bit harder. But literally was like 2-3 mins a side going slow so not to have the blade jump.
The 7" cut off wheel was perfect!! I don't think my 19.2V Craftsman grinder has the RPM of the corded Metabo, but it worked fine. Took me probably 10 minutes for each arm (and a battery for each arm). If I have to do this again, I'll wear a dust mask. That crap gets everywhere...I used white lithium grease, we'll see how well it does.
Got both control arms swapped, rear pads changed and winter tires/wheels on. Timing belt on Saturday....
As I was watching sparks fly near my gas tank, 3 fire trucks rolled down my street with sirens blaring. A neighbor's detached shop was burning to the ground (rural fire department) as I was spewing sparks in my own garage...kind of eerie...
![Name: 2015-11-19%2017.08.48_zpsd8d7v0dp.jpg
Size: 144.8 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/64553d1501396156-rear-toe-issues-2015-11-19%252017.08.48_zpsd8d7v0dp.jpg)
![Name: 2015-11-19%2021.05.47_zps0gnj2tho.jpg
Size: 313.9 KB](https://acurazine.com/forums/attachments/3g-tl-tires-wheels-suspension-97/64554d1501396156-rear-toe-issues-2015-11-19%252021.05.47_zps0gnj2tho.jpg)
If you NEED to tuck the wheel in a bit, just get the SPC top camber arm.
Serves another good example and reminder that Ingalls arms are still crap. I also went back from Ingalls to OEM lower arms plus SPC upper adjustable arms. Alignment has not gone out for a whole year with stiffer rear using this setup. My Ingalls arms were sent directly to Ingalls for inspection... still no news on that. Yeah they suck.
It might be a good idea to pull those bolts and put some kind of A/S on them, dunno.
OEm with SPC upper arm. I think rockauto has other brand of adjustable upper arm also.
Also I have the same issue as nfnsquared as I haven't moved the arms in a while so they were extremely hard to move since the threads were covered with rust and other bad stuff from snow and salt
aomechmarine
ILX Performance Parts & Modifications
12-30-2015 09:15 PM
CryingMidget
11-13-2015 07:47 AM
11-09-2015 04:11 PM
MayorMcCheese
11-09-2015 12:25 PM
