Rear feels wavy after alignment?
hey guys quick question. I lowered my car last month on bc coils and had the
ingalls rear camber kit installed and everything was good, the ride was nice but today i went to alignment and after on the way home the car feels wavy in the rear like it has a wobble anyone have this issue? i called the tech and he said its adjusted to oem specs so not sure what to do any help will be good, thanks
Far from a suspension expert, but don't forget that when the TL is lowered, because of the rear suspension, upper/lower arms, the alignment can be set to factory specs with camber/toe kits, but under real world driving conditions the camber changes drastically from OE with more positive camber.
Your toe is out compared to your front. It may be straight but is your wheel straight? They should set the toe to 0.00 on either side. doesn't matter if its 0.22 and even
the front toe is pretty good. rear toe can be adjusted closer.
caster is not adjustable
camber won't usually make it wavy or floaty. And 1 degree of negative camber is probably "desired".
If you can't hit zero on the the front toe, then go negative on both left and right sides. And they wont be able to hit zero unless they are lucky.
rockyboy
12-06-2022 02:29 PM
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
