Rear Camber (ingalls, SPC, etc.)
Old 09-30-2014, 11:20 PM
abpmerg's Avatar
I searched around all over these forums and the internet and still have not found the answer to my question. If i wanted to run a lot of negative camber in the rear, like ~-8 degrees. Are there any kits made that can achieve that without modification?
I'm lowered on function and form type 1's and I'm sitting at ~-3 degrees right now no other modifications.
I know many of you will disagree with my choice, but any help is appreciated.
Old 10-01-2014, 12:02 AM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
The SPCs MIGHT get you there. I had to open them up to match the length of the stock arms. Fully closed, they MIGHT get you there, but I just don't know.
abpmerg (10-01-2014)
Old 10-01-2014, 02:03 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
camber kits add/subtract from your existing camber. the ingalls is advertised as -1.5 to +3 so if you're currently at -3 then you will be able to go anywhere from -4.5 to 0. the spc one is rated from -2 to +4 so if you have both you can go from -6.5 to +4. so if you want -8 you'll have to lower your suspension some more to make use of that suspension geometry.
Old 10-01-2014, 11:36 AM
Former Sponsor
Excelerate's Avatar
I don't think you'll make it negative 8 degrees. That's a lot of negative camber. But as was mentioned you could do the SPC and INGALLS rear kits to get the most negative camber possible.
Old 10-01-2014, 02:23 PM
abpmerg's Avatar
thanks guys, i think ill go with the spc max it out and go a bit lower
then ill finally get some pics of my car up on here
Old 10-01-2014, 05:09 PM
nfnsquared's Avatar
sub'd to find out how negative the SPCs went ....
Old 10-01-2014, 09:06 PM
abpmerg's Avatar
Before i go ahead and order the kit i wanna give my shop a call and get an estimate price for the install. Work and schools too hectic right now and from what i understand its a pain in the ass DIY.
What did you guys pay for yours?
Old 10-01-2014, 09:49 PM
nfnsquared's Avatar
IMO, it's a fairly easy DIY. I bought mine from THMotorsports for $148.56 shipped. It was the cheapest price I could find. They shipped very fast. I was in a hurry, but if you have time, you might contact some of the Azine vendors and see if they can match that price.
The DIY is below. You don't need to replace the boots.
https://acurazine.com/forums/tires-w...t-boot-886608/
Old 10-02-2014, 08:36 AM
abpmerg's Avatar
Does anyone know what KidJdm was running? The black TL with Vossen Cv1s at -11 degrees camber?
Old 10-13-2014, 08:22 AM
DarkTower19's Avatar
I just placed an order for the SPC upper arms - just want to confirm: so it's no longer necessary to replace the existing SPC boot? I did see your post in the link above regarding SPC stating they addressed the problem with the old boots tearing. I still debating whether to go ahead and switch them out or not. How are yours holding up thus far?
Old 10-13-2014, 11:25 AM
nfnsquared's Avatar
Well, it's only been 40 days, but they are fine. As I already noted, the only reports of cracking that I could find were with the old red boots.
I'd wouldn't mess with it.
Old 10-13-2014, 11:39 AM
Former Sponsor
Excelerate's Avatar
Thanks for the DIY.
And if you or anyone other member needs anything or want to match a price please send us a PM.
Old 10-13-2014, 11:43 AM
Sounds good. Thx man
Definitely looking forward to getting my rear camber fixed. Toe is good at 0.01. But the camber went way out (especially on drivers side) after installing springs over 2 weeks ago.
-2.3 LR and -1.5 RR I'd like it more flush than it is...shooting for around -1.0
BoricuaTL
04-08-2016 01:08 PM
james357
02-13-2016 02:37 PM
o8 ENVII 8o
11-30-2015 04:23 PM
mugen_kid
11-13-2015 10:38 PM
HydrasunGQ
09-14-2015 10:14 PM
Quick Reply: Rear Camber (ingalls, SPC, etc.)
