Rear camber
Rear camber
I recently installed Koni sport shocks and Eibach springs, the drop was approx 1.75” at the front and approx 1.25 – 1.50 at the rear. I let the car settle for a week or 2 before getting an alignment. We found the toe to be out all the way around, which is common after a drop and that was corrected. Front camber was corrected and within factory spec but the rear was out -2. I just installed new tires on the car and was wondering if that number warrants a rear camber kit?
Former Sponsor
Any negative toe will wear out your tires prematurely. I'd recommend the Ingalls rear camber kit, which includes an arm for toe and camber.
You need a qty of 2 of the following:
http://store.excelerateperformance.c...5/i-60220.aspx
front camber can't be corrected without the kit. Toe can. And I have been riding for 2 years on a set of general exclaim tires with -2.3 camber in the back and my tires are just fine. I do notice very minimal difference between thread depth on the inside and the outside of the tire but it's not a big deal at all.
Once again, to obtain even wear, get all the corners in spec and the only way to do this is with a kit as mentioned above. Can't understand why people spend all the money on tires, wheels, springs, shocks, coil-overs and don't want to spend the few extra dollars to ensure that everything is in spec. Beyond me.
read the article
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/do-i-need-camber-kit-606757/
the answer is as long as you have a proper alignment and your toe is at 0 you will be fine. forget the camber kit put that money elsewhere
read the article
https://acurazine.com/forums/showthread.php?t=606757
Bottom line is to get the kit, get an alignment and be done with the hassle of tire wear, but on the other hand, if you want inside tire wear or heavy negative camber, leave it as is.
How can one not buy the kit at the price listed as it would only be $145 for both sides, and remember the list is $462.02.
Well, if the camber is out you can't have a proper alignment without the kit. If you read the article Marcus, as well as many others, state that they have lowered cars, set the toe, and the camber is out but the inside wear will be slight.. If I spent the money to lower a car, along with the cost of tires and or wheels I'd certainly spend the few extra dollars ($145) to have the car in spec. Now, if some of the people want the extra camber to ensure the tires fit under the vehicle, now that's their choice and an entirely different scenario and should voice no complaints about inside tire wear.
It's $155 total for both sides right here on our site:
As stated before, any car that the rear camber is out of spec, for a $155 it's well worth the price to save the tires.
Unless there is a reason that you must run -2 degrees, just get it corrected. Though -2 degrees isn't enough to affect tire wear drastically as long as you adjust the toe to compensate, it does make the car feel twitchy at times. $155 is cheap so get it done for peace of mind.
Don't know what a shop would charge to install the kit, but I'd do it all day long for $250.
camber wear is blown way out of proportion (unless you are running stretched tires at -6 degrees camber). And yea you notice wear but in the last 2 years with -2.X amount of camber, the difference in thread wear is so minuscule that it's not even worth mentioning.
Like I've stated many times before, if one doesn't want the camber to be in spec, leave it alone and let the tires wear unevenly albeit slightly. To each their own.
BoricuaTL
04-08-2016 01:08 PM
