Quivering in steering wheel around 70mph
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
I've had quivering in my steering wheel (around 70mph) for some time and I initially thought it was due to sidewall damage I had on one tire. The quivering however did not go away after replacing all 4 tires with Kuhmo's about 1 month ago. I have balanced the Kuhmo's twice (at the same shop) but the problem persists. Now I am unsure whether the problem is with the tires or some other suspension component. Any suggestions on how to proceed?
Thanks.
Thanks.
Head a da Family
Thanks.
Thanks.
If you do need a wheel, try http://fixrim.com, $135 for a remanufactured TL wheel with your trade in.
The quivering sometimes seems to start around 60mph and I have felt it up to 80mph (I typically don't drive faster than 80). It does not get worse with increasing speed.
I watched the shop do the balancing, and each time the machine seemed to balance the wheel OK. I wonder though if some balancing machines are more sensitive and accurate than others. If yes, how do I find a shop with one of those in the South Jersey area?
Head a da Family
I meant WATCH THE EDGE OF THE WHEEL ITSELF AS IT SPINS. That's where & how you'll be able to determine whether the rim is really bent.
CEO, Team Anthracite
Consider getting the tires balanced with a Hunter Roadforce machine. The machine should be able to tell you if you have a bent rim and will help the technician identify the high and low points on the tire.
NY/NJ TL Crew
1 Post
Its most likely balancing.....i put on new tires in a shop and they had an old balancing machine, so now i get the "quiver" or slight vibration, so im going to get it redone at a shop with a nice hunter machine ;]
P.S. 20 degrees cooler this week (hence lower tire pressure) and the quivering is not as noticeable. Makes me believe it is a tire not a rim problem.
Head a da Family
Is there an easy way to find a shop with one of these machines, or do I have to just keep calling shops until I find one
Transmission problem related? Check out this thread:
https://acurazine.com/forums/showthread.php?t=143681
Problem fixed. Had it done at the dealership (closest place with a RoadForce machine). Did not even do a road force balance. Just a regular balance by a good tech. They said the previous place which did the balancing put weights only on the outside, when it was obvious that weights were required on the inside also.
My only gripe? $79.99 for balancing 4 wheels is nuts IMO.
rockyboy
12-06-2022 02:29 PM
EvilVirus
12-10-2015 07:38 PM
