question with tein SS..
Old Mar 29, 2007 | 12:44 PM
VtecTL's Avatar
Tee EL
hey guys, im still kinda new to the suspension thing and im trying to get me a set of the tein ss coilovers. my question is, it says it dosent come with the upper mounts. what do they do and do i need them? also, do i need the type-r bushings? says it minimizes ride comprimse. any feedback would be appreciated. thnx!
Old Mar 29, 2007 | 01:45 PM
leeo's Avatar
You do not need to have the upper mounts , you can use yours however when you do this you have to break down the suspension parts in order to take off your current tophats. I would suggest you pay the extra $100 or whatever it is and get the upper hats so it's easier to swap back your suspension later ( i personally did this and im running the Tein SS's as well ). You do not need the type-r bushings but if your a suspension guru or enjoy taking corners hard you might want to consider them as they will make the suspension slightly tighter but it might feel a little more bouncy , just depends on your driving habits on if you want to get them or not. If you have anymore questions you can ask me and i'll try to help.....
Leo
Old Mar 29, 2007 | 03:22 PM
01tl4tl's Avatar
Check with the TEIN pro
Marcus at MrHeelToe, an acurazine vendor
see his post in Off Topic, Sponsored Sales area and click the Tein link in his post
or best thing to do is call him direct
1-949-295-1668 california time zone
Shop is right by Tein in LA and he is certified by them as an installer too
He can pre-assemble and adjust the shock/spring height
so its a plug and play assembly
Old Mar 29, 2007 | 04:37 PM
VtecTL's Avatar
Tee EL
thnx guys i do appreciate the info. it was a big help. thnx!!
Old Mar 29, 2007 | 05:19 PM
Kennedy's Avatar
OMGWTF4THGENTL
The type R bushings will NOT make the suspension more bouncy...
They reduce/ellimainate the "slop" in the rubber bushings in the top of the coilover hats. This makes the supension that much tighter... but tight = more road vibrations.
I highly reccomend them, and the 07 Type-S also comes with these bushings.
Old Apr 1, 2007 | 12:53 AM
Excelerate's Avatar
Former Sponsor
TEIN hasn't released the SS-P's yet for the 3rd gen TL. You would have to reuse your stock upper mounts and go with the SS unless you wanted to wait for TEIN's release of the SS-P.
PM me if you need any TEIN part.
Old Apr 1, 2007 | 08:20 AM
ACCURATEin's Avatar
tehLEGOman
You could also order the TL SS kit and the Honda Accord upper mounts.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
lanechanger
Oct 13, 2015 10:56 AM
navtool.com
Sep 25, 2015 05:15 PM
4drviper
Sep 23, 2015 07:42 PM
