Question on A-spec suspension
Just a quick question everyone. Can you use the A-spec suspension (Acura part#08W60-SEP-201A) for the 07-08 AT on a 04-06 AT TL? Thanks
2005 AT with the -401A:
All the A-Spec kits are pretty much identical in the rear with .5-.75" drop. The front suspension is the main difference between all the different A-Spec suspensions. I believe the -401A is for the 07-08 Base AT(they didn't make 6SP Base these years) I'm pretty sure the -401A drops the front end lower than the 04-06 5AT A-Spec suspension as you can see from the pictures below.
MrHeeltoe
79
10-14-2015 08:47 AM
nuldabz
09-03-2015 05:49 PM
