Question on Rota Grids
So I've been looking around for pics of Rota Grids on 3G TL and realized that I don't see center caps on these wheels. I'm interested to know why is it because they don't fit or just because ppl choose not add them on. Reason why is because I just ordered a set of rota grids and I wanted to know if I need to get different center caps.
I'm wondering too. I hope the stock Acura wheel caps can fit, so I can paint them the same color as wheels and put them on.
These are the wheels I'm looking to get: Grid 18x9.5 +38 5x114.3 flat gunmetal.
You also need to get 12x1.50 lug nuts and φ73.1/φ64.1 hub rings for these wheels to fit.
Not sure if the center caps fit or not, but I'm going to guess and say they leave them off purposely because they don't want others to know that they are Rota's and want people to think they are it's more expensive counterpart (not sure what the Rota Grid is supposed to replicate off the top of my head). Nothing against Rota's because I used to have them on my Subaru a few years back before I switched to Axis Widetracks.
Originally Posted by chincster
We used Rota wheels this season for Touring Car competition in a Civic. We chose Rotas because they were the only ones with the size and offset available (15x8, 35ET) and also lightweight. During the season, we broke almost 8 wheels during racing competition and not in accidents, etc. Typical breakage include the face (spokes) separating from the rim and hub separation from wheel. Tires used were full slicks with stiff low profile sidewall. There are some examples of Mazdas in World Challenge that experienced this type of breakage at Laguna Seca when the car was driven through the corkscrew. At the end of the day, you get what you pay for. However, budgets will always dictate what you can buy. The quality of Rotas is indeed not up to par with a true wheel manufacturer with R&D and racing heritage.
The majority of drivers will not "stress" these wheels for DD or even some events at autocross or tracking, as most don't drive hard enough to do so. Not because they can't drive, but usually the tires used limit this ability. Hitting potholes, curbs, etc are not proper tests that can indicate wheel quality or strength. Hot temps from constant and hard braking, high g's in corners, downhill and uphills and then constantly repeated, like those experienced in road racing, definitely highlights a wheel's quality.
Using Rotas with your avg street tire will probably be good enough for almost all consumers in that case, as there are probably no reported incidents of breakage. If you run a competition tire like a semi or full slick, run aggressive\racing brake pads, then you probably won't be buying Rotas anyways.
So if you want Rotas, go ahead and get them. If you go to competition, I recommend running your stock/oem wheels; can't go wrong with those.
I do hear a lot of good things about Rota. The old ones suck, but in the last several years they have improved a lot.
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
