Question about : Work VS-XX 18x8.5 +32
RIP RBP
there is a chart on the Work website that will tell you what size/offset you can get with the R disk the R disk is BBK friendly
just in case you're asking what is a R disk these are 3pc wheels and there is a inner barrel, outer lip, and disk (which is the design of the wheel the mesh)
hope this helps
hope this helps
Confusing Name Guy
They need to tell you what disk type it is. If its Hi-Disk, its more than likely it will clear, as most wheels clear with +33 offset on the TL. If not, you could run spacers. 18x8.5 +32 isn't terribly aggressive, and even if you were to put on beefy tires you could probably get away with a 10 mm spacer to clear Brembos if necessary
Oh Sickest TL (11-25-2015)
may not be a piece of useful info, i've tested fitted 18x8 +38 VSXX and it didn't clear the brembo but it looks like if would if i had a 5mm spacers. at 18x8.5 +32 (depending on actual disk type) it looks like 95% chance it will clear but don't quote me on that. lol
NBP_BALLER
10-22-2016 10:31 AM
Johnbright2020
1/2G MDX (2001-2013)
11-22-2015 12:29 PM
