question?
Old Oct 23, 2001 | 10:26 AM
TypeSDragon's Avatar
Loving my 08 TLS!
question?
How wide of a tire can I go with my stock TypeS rims?
Old Oct 24, 2001 | 08:42 PM
ShadyUpInSmoke's Avatar
Resident Volkswagen Dork™
you can fit 8 inches wide comfortable...8.5 is really pushing it. check the specs post...that will help you more than i can.
Old Oct 24, 2001 | 08:44 PM
whoops, i was thinking rim...i think 245 is pushing it but im not all to familiar with tires as i am with rims...sorry .
Old Oct 25, 2001 | 04:07 AM
Lawaia's Avatar
Moderator Alumnus
245/50-16 will fit on a 6.5" wheel but not so sure if it will fit without rubbing.
I would go with 225-55/16. 245's would be overkill.
Old Oct 25, 2001 | 04:35 AM
SimTypeS's Avatar
...and then there was One
I think Zodiak is using 245. That's THE widest I would go. I would recommend 235 as the widest, though. 235/40/17 sound right? Someone else can do the math, but that should be about the same overal diameter/ rolling diameter as stock, so it doesn't throw off your odometer/speedometer.
Can we ask why you want to go wide ? Sure it is more traction, but it also creates more friction and less aerodynamic... but, a meaner stance.
What tires are you looking at getting?
Old Oct 26, 2001 | 01:48 AM
Lawaia's Avatar
Moderator Alumnus
Zodiak is running 235/45-17....which are the closest match to stock and the widest I think you should go with.
Old Oct 26, 2001 | 09:15 AM
fahoumh's Avatar
Shogun Assassin
In Canada, the TL-S comes with 17x7's....what's the largest tire you can put on those?
Old Oct 26, 2001 | 10:38 AM
245 on 6.5"??? that is just asking for it. the tire wall would bulge like no other!!! the optimal fit for wheels tire setup is that your wheel is 90% in width according to your tires. and with 245 on 6.5" that is about 66.3% (1inch = 25.4mm). even an 8" wheel is only recommend to be used with 225~235 tires.
Old Oct 26, 2001 | 10:42 PM
adamyankee's Avatar
Don't know if this what you mean, but the wheel/tire aspect ratio should be above 70%.
With 6.5 inches, a 235 is exactly 70% so any wider is considered unsafe.
Old Oct 27, 2001 | 12:06 AM
fahoumh's Avatar
Shogun Assassin
hey, adamyankee, dude! Haven't seen you post in a while.....good to see you're still around
Old Oct 27, 2001 | 12:34 AM
Lawaia's Avatar
Moderator Alumnus
Originally posted by Lexus_IS300
245 on 6.5"??
Why...do you see a problem with that?? Unfortunately I mistakenly equated "stock wheel" to 16". So as I posted, 245/50-16 will fit on 6.5" wheel.
Old Oct 27, 2001 | 01:30 AM
fitment is one thing, but safety and performance is another.
Old Oct 27, 2001 | 02:44 AM
Lawaia's Avatar
Moderator Alumnus
Care to explain....
Old Oct 27, 2001 | 05:41 PM
2K2 TLS's Avatar
17x6.5 no bigger then 225
17x7 no bigger then 235
these numbers are pushing it, but still safe to run go wider and al i can say is GOOD LUCK
Old Oct 28, 2001 | 03:52 AM
Care to explain....
6.5" wide, 245 tires. no explanation needed.
Old Oct 28, 2001 | 04:07 AM
SimTypeS's Avatar
I agree with the last post. Also, I don't think it matter the diameter of your wheel, just matters the width. Also, you don't want to get too narrow of a tire, either. Too wide, or too narrow is just unsafe. Check out tirerack (lots of info), then go and buy your tires from Tim.
Old Oct 28, 2001 | 07:25 PM
bdimc2001's Avatar
Charles, after some research, I think u should go 225/50/17 as the replacement size for your tires
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
