QUESTION 20x9 all around will fit? will they poke out nasty?
basically i want to get some 20's and the ones i have picked out are 20x9 does anyone have this width or have experience with these on a TL because i really dont want them to be poking out all crazy but if it will look right ill get them b/c they have got a big deep lip. also, the tires that come with them are 245/35/20, do i need to go down to a 225 series. My car isn't dropped at all. someone lead me in the right direction here!!!!!
fyi...stock offset is +45. generally you are safe in the 35-45 range. the lower the offset, the further out towards the wheel well it will sit. on a 20X9 rim, you should go with at least a 245-35-20 tire, unless you really want to stretch the tire which will give you less lip protection.
'06 750Li Sapphire/Creme
My wheels are +30 offset. They are 8-inches wide. Mine line up as far out as possible (flush with the fender). Since yours are 9-inches wide, they would stick OUTSIDE the wheel wells by AT LEST 1/2 an inch. not good
wusty23jd
09-24-2015 11:41 AM
