Purchasing stock suspension?
Old 08-10-2012 | 08:35 AM
HyperVTEC's Avatar
My 06 TL feels like it needs new suspension and the first thing I did was call up my local Acura dealer and got a quote for all 4 struts and springs. The price I got was a lot more than I had expected but what's even mover compelling abut the price is the difference in prices for front springs.
Is there a reason why the prices are different? Is the tension on the springs different from left to right?
Old 08-10-2012 | 08:37 AM
^yes, to compensate for the heavier left side.
the tranny/battery hangs over the left side.
If changing suspension and dealers pricing is way out of your league; why not go aftermarket?
HyperVTEC (08-10-2012)
Old 08-10-2012 | 08:54 AM
HyperVTEC's Avatar
I see. The reason I started looking into stock suspension was because I thought it would be easier to just replace old with new stock suspension. Also because I wasn't changing the car height. I did do some looking around for aftermarket suspension and to be honest I am not mechanically inclined so I was pretty blown away by the amount of suspension options available.
Old 08-10-2012 | 09:00 AM
Acura also sells the Acura Specified suspension, or commonly known as the Aspec suspension.
it retains stock like ride while dropping it less than an inch.
I have this on my car.
most cant even tell that its dropped, it looks factory.
Old 08-10-2012 | 09:13 AM
HyperVTEC's Avatar
I like the sound of that. Does that come in a kit or buy them individually? The quote that I got was for individual parts because they don't sell them or the parts don't come in a kit.
Old 08-10-2012 | 09:15 AM
I've seen the Aspec suspension package on Ebay for around 400-600 dollars.
these ebay ads are from Acura Dealers, so not to worry about imitation parts or being ripped off.
also, there are some Aspec suspension kits floating on the black market here on acurazine.
you mentioned that you arent mechanically inclined.
if you were to take it to a shop to install, dont get ripped...
it shouldnt be more than 150 for labor.
Old 08-10-2012 | 09:22 AM
Otacon's Avatar
flappy paddles
Aspec is the way to go.
Old 08-10-2012 | 09:23 AM
HyperVTEC's Avatar
Thanks ma man. You have been very informative. I have a buddy that works on my car so he will most likely do the suspension swap but since he doesn't have wheel alignment machine, I am going to have to take it elsewhere to get that done. $400-$600 for suspension plus ~$200 for labor and alignment sounds like a good enough deal for me.
Old 08-10-2012 | 09:56 AM
Bearcat94's Avatar
AZ Community Team
This will vary some depending on location. The better way to look at it is 3 to 4 hours shop time at the going local rate.
Here that's about $60/hr or $180 - $240.
Old 08-10-2012 | 11:01 AM
swoosh's Avatar
takin care of Business in
HyperVtec....just a suggestion....go aftermarket....
for installing suspension as mentioned it should not be more than 200 bucks....check the 3G garage for DIY instructions...
Old 08-10-2012 | 12:11 PM
HyperVTEC's Avatar
What would you recommend for aftermarket suspension? My company gets discounts on Koni, btw.
justnspace (08-10-2012)
Old 08-10-2012 | 12:14 PM
nice!!
I mixed and matched the Koni yellow shocks with the aspec springs.
I had a buddy that gave away his aspec springs to me.
H&R sport springs are an awesome combination with the Koni's
and will drop it even more so than the aspec springs.
Old 08-10-2012 | 12:24 PM
HyperVTEC's Avatar
nice!!
I will look into the the first option if that's a better combo than going straight a-spec.
Old 08-10-2012 | 12:27 PM
way much better combo.
BUTT, the aspec suspension is sold as one piece.
Unless you find some one that has broken them apart, like my buddy who just gave the springs to me.....you'll end up spending more.(unless your hook up on the koni's is significant!!)
http://store.excelerateperformance.com/
check this website out to see what all is being offered, save the Acura specified parts.
Old 08-10-2012 | 12:45 PM
swoosh's Avatar
Hyper you have couple options here buddy:
1> only height adjustment - tein basis and couple other names which dont come to mind LOL
2> height + dampening - tein SS, XLR8 ISC N1, HT SPEC, etc
I would personally go for the XLR8 ISC N1 just coz it offers sooo much for the $$$
for 850 shipped out get
coils
tops hats
dampening adjustment
preload adjustment
for tein SS, which is ~$1000 shipped
you get
coils
you will have to reuse your top hats and you will not be able to adjust preload....
hope this helps
Old 08-10-2012 | 12:50 PM
HyperVTEC's Avatar
coils
tops hats
preload adjustment
you get
coils
hope this helps
I appreciate all the helps and suggestions here. Thanks guys!
Old 08-10-2012 | 12:53 PM
TLDude876's Avatar
Chapter Leader (Houston)
I would go the coilover route as well
1fatcrxnem1
22
06-01-2018 01:23 AM
proxus
09-16-2015 06:18 PM
Quick Reply: Purchasing stock suspension?
