Progress RSB Common Setting
I've ordered my Progress RSB for my Type S. What is the preferred/common or best setting (street or track). I don't track mine but want it to handle better around turns and still give a compliant ride.
The ES bushings used don't actually fit the TL properly, they have to be tweaked to fit, and that may have also contributed to the problem.
I have 1.25" drop with coilovers on a medium setting. No problem with my RSB or endlinks for about a year now.
just dont push your components beyond their tolerance points and you'll be fine.
It's good anytime, as soon as possible. In fact, if I were to only have one single mod on our car, the Progress RSB would be it. You already have an oem RSB, the progress is simply thicker and stiffer. $120 bucks, 45 mins to install or remove. It improves cornering 3 fold. Its a no brainer.
But in those couple of cases I mentioned, it wasn't the end links that failed. It was the bushing mounting bracket on the sub-frame (1st two links below).
https://acurazine.com/forums/showthr...hlight=bushing
Interesting. Those threads also had several references to the endlinks breaking as well though. Also, I wonder if those are a result of using components not quite designed for each other. i.e. comptech rsb with ES bushings and therefor excessive stress placed on components. But again, without knowing their full setup and driving conditions, its hard to say. i.e. if they have slammed vehicles with tight suspensions, if they drive aggresively, if they have lots of bad roads, etc. Regardless, these definitely appear to be exceptions.
It's not hard cornering that breaks the mounts and end links. Bumps and taking driveways at an angle puts much, much more stress on these components than taking a corner at the limit.
Stock suspension cars will see a higher failure rate of swaybar mounting points. Stiffer springs/shocks take some of the stress off of the bar.
Maybe a 75mm swaybar too.
SidhuSaaB
May 30, 2020 12:40 AM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
braveheart
Sep 7, 2015 08:12 AM
