View Poll Results: Did You Install Your Comptech Rear Swaybar Successfully without dropping the exhaust?
Yes
80.00%
No
20.00%
Voters: 10. You may not vote on this poll
POLL: Comptech RSB Install (I Know, 1 more post)
Many posts have been made discussing the install. Why were some self installs done without dropping the exhaust while others had problems?
Is it due to prior suspension install upgrades?
Why did some run into problems without dropping the exhaust?
According to this post there is no need to touch anything but the swaybar. I might get the Comptech swaybar in a couple of months.
https://acurazine.com/forums/showthread.php?t=108602
Registered VTEC junkie
The stock bar can be manipulated to come out at an angle. It's a tight squeeze between the bar and exhaust pipe. The exhaust pipe can be pulled down a bit with one hand to allow some space to slide the bar out. I took mine out with the driver side of the bar sliding to the front towards the driver seat-if you can picture that. It will come out!!
cycdaniel
12-17-2019 10:58 AM
urbtsx
03-04-2017 06:53 PM
k6biv
09-10-2015 06:37 PM
