Please HELP! How to remove the rear seat to install the suspension?
please show me how to remove the seat back i'm in the middle of install the rear suspension. so far i have removed the headrest, the seat cusion and unscrew the 4 bolt but i can't remove the seat back. please have it in detail picture would be nice. Any advise are appreciated.
^ search dude...
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
That's the 3G garage, there should be instructions in there for a lot of stuff.
^ search dude...
https://acurazine.com/forums/showthread.php?t=553554
^ it's in there... you didn't look hard enough...
Hahaha... the title of the thread is VERY similar to the title of your thread... good luck!
https://acurazine.com/forums/3g-tl-tires-wheels-suspension-97/how-remove-back-seats-put-suspension-3g-garage-f-070-a-567460/
There is a slit between the stitching under the rear headrests. Use a 10mm socket on a 6" extension and put it inside the slit and feel around for a bolt. You will find it within 30 seconds.
Turn it about 6 full turns and you can lift up on the seat and pull it out and away from the rear deck. If that doesn't work for you, just remove the bolt entirely and screw it back on before putting the seat on. Then "hang" the seat on the bolt and tighten through the slits in the stitching.
johnpancakes014
04-08-2016 06:47 AM
