Please Help buying a-spec wheels
Guys,
Im about to buy this set from this guy it a-spec wheels 18x8 that come with this tires size 225/45ZR/18. My question is does this tires size messup my stock suspension because factory recomended 235/40/18 if it's 18inch rims. Thanks
there is a diameter difference of 2.5 %, which can affect the speedo pretty good. if you are going 60MPH according to speedo, with this tire you will be actually traveling at 58 MPH
the 17" rim is equipped with 235/45 tire, so that puts your wheel/tire total height at 25.37 inches. going with a 18" rim with 225/45 (225? - you sure?), that puts the total ride height at 25.97", just a bit taller than the original, but you would actually sit only about .35" higher than stock, which is not much. <---- i believe this is correct, if im wrong, please correct!
06 TL 6spd. Navi/A-spec
I had aspec wheels with stock suspension and it didnt look higher at all, now i have the aspec suspension and it sits a tad bit lower here are some pics..
aspec wheels stock suspension
![](http://memimage.cardomain.net/member_images/7/web/487000-487999/487481_182_full.jpg)
apec wheels with aspec suspension
![](http://memimage.cardomain.net/member_images/7/web/487000-487999/487481_199_full.jpg)
My tire size is 235/40/18 which is the recommended yokohama tires!
Originally Posted by PLATTS
Was your car parked by the boat place close to Albertson i think Monday or Tuesday, if so your car looks awsome.
nuldabz
09-03-2015 05:49 PM
