OUCH! Wheel cracked
OUCH! Wheel cracked
Well...went out to the 3 month old Anthr/Gray/Auto last night and noticed the tire was flat. Put the donut on and took the tire in to be filled....and look for a hole. Well, the good news is the tire is fine. The bad news is that the wheel is cracked! I hit a bad pot-hole about 2 months back right after I got the car which must've caused an initial crack that eventually got worse. !&^@*&^*&!^ QUESTION: What am I looking at for a new wheel? $250 or so sound about right?
Call to some local dealers. They have takeoff sets from cars that are upgraded with A-Spec packages or for people who want upgraded rims. I found a dealer in NYC area who would sell me a new take off rim for $165. I eventually bought a slightly scraped rim from another dealer for $39. It came off of a demo which was sold. The damage was so minor that it made it a good buy. Based on what I've seen on this site, you wil eventually scrape your rims on potholes or curbs. I wouldn't spend $300 for a new rim unless absolutely necessary.
Regards,
Regards,
This points out the reason for checking tire pressures regularly - an under inflated tire is much more likely to contribute to a bent/damaged wheel if hitting a hole - particularly true with the low profile tires as found on our machines! I run into guys who have had this happen quite often on motorcycles - a small drop in temperature means a substantial loss of pressure (Boyle's Law?) since the total volume is quite low.
Originally Posted by Aquineas
Probably much worse if you buy it new from Acura. For reference, when I bent the rim of my Alti's wheel, Nissan wanted $400+ for a stock replacement.
dont even get me started on this subject, i already bent 2 and cracked one,
same thing happened with my tire, so i brought it to the mechanic and he found the crack
in the rim, so far this car has cost me alot of unecessary rim cash.
cycdaniel
Dec 17, 2019 10:58 AM
