Offset question
Old Dec 26, 2003 | 02:58 PM
tencamel's Avatar
9th Gear
Question Offset and tire sizes
I just got a set of 17"x7" wheels with +42mm offset for my 99tl. Would anyone have any suggestions on tire size for this offset? I am planning to put on set of 235/45/17 Bridgestone RE750. Would they rub? Should I use 215/50/17 tires instead? Anyone have any comments on Bridgestone RE750, RE950 and expedia S-01 tires?
Thanks,
Old Dec 26, 2003 | 11:20 PM
Lawaia's Avatar
Moderator Alumnus
215's would be the safe bet. 225's may rub, and you'll need to trim the bumper tab. What kind of wheels did you get?
Old Dec 26, 2003 | 11:50 PM
tencamel's Avatar
9th Gear
i got a set of Tenzo Passion 5 wheel. What is the recommanded offset and width for the 235/45R17? What should be the correct tire pressure for 215/50 and the 235/45?
Thanks,
Old Dec 27, 2003 | 12:48 AM
Lawaia's Avatar
Moderator Alumnus
17x7.5" +49 offset would do. Check on the sidwall for proper inflation amounts as specs differ from one manufacturer to another
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
navtool.com
Sep 25, 2015 05:15 PM
mellsonnj
Sep 24, 2015 04:42 PM
