Offset help
Old Mar 26, 2008 | 11:56 AM
TrevorT's Avatar
Offset help
Okay I've searched and searched and only made myself more confused.
Rims will be a 19X8 multi piece 5-spoke.
What offsets can I expect for a good size lip? 38??
Do not want staggered.
Any help is much appreciated as I need to order soon since they take a while to get.
Sorry, car is 07 Type S.
Old Mar 26, 2008 | 04:33 PM
VIP-A-SPEC's Avatar
REDONDO RED
With a 19x8 you should be fine with et 38. You would not want to go any lower than that. I have 19x8.5 with et38 with aboiut a 2.75 lip.
Question for you. Are you, or have you lowered it at all? I am having fairly minor rubbing issues with a Comptech drop with 245s
Old Mar 26, 2008 | 04:41 PM
TrevorT's Avatar
Not lowered yet, but I will be adding a TEIN SS kit at the same time.
I don't plan on taking the car down a lot but would like there to be a small gap.
Do you think your rubbing issues have to do with the 8.5" width? What are your tire sizes/brand?
Old Mar 27, 2008 | 11:03 AM
VIP-A-SPEC's Avatar
REDONDO RED
I am running 245/35 R19 Bridgestone Pole Positions. If I could do it again I would either have gone with a 19x8.5 et40 or 45 with the same tire. I am no expert, but I think you may have some rubbing issues with the SS and an et38. However, part of my rubbing issues are do to the a-spec kit.
My recomendation, go with a 19x8.5 et45 with a 245/35 19 and the Tien SS and you will be good to role with no problems. Hope this helps. But please remember, I am not an expert. This is only from my experience. Best of luck bro
Old Mar 27, 2008 | 12:48 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
you said multi-piece wheels... right???
Are they going to be custom making the wheel for you??? If so, why such a narrow wheel 8"???
since you have a type S with the big calipers in the front... you are going to need a HIGH DISK so you're not gonna have much of a lip... believe me I know...
Old Mar 27, 2008 | 12:55 PM
rodneyc77's Avatar
did you considered that he has a Type S??? there is no way he could fit a 45mm or 40mm offset while still retaining some lip and clearing his big breakes in the front... well, unless he goes MUCH wider...
In order to give TrevorT advise here... we need to know what wheels he's looking at??? what are the available wheel disk types??? Is TrevorT stuck with the 8" wide wheel??? with this info... we can help you better...
"cause there are various parameters to consider when an offset is calculated... it's not black and white... 'cause one wheel design with "X" offset spec can clear the BBK and another wheel design with the same "X" offset spec does NOT...
Old Mar 27, 2008 | 03:52 PM
VIP-A-SPEC's Avatar
REDONDO RED
I was unaware that he was type s. My fault bro. Hense the statement that I don't really know shit except for my experiences.
Old Mar 27, 2008 | 04:26 PM
TrevorT's Avatar
Sorry, it will be a 8.5" width. Racing Hart is the manufacturer and yes it's a multi-piece wheel. I'm not sure on the wheel disk types but will try and find that out.
Thanks for the help so far guys. It's not easy with this car. I remember 10 years ago buying wheels seemed so much easier!
Old Mar 28, 2008 | 12:17 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
racing hart makes wheels to clear bbk... what I would do is pm rodney the wheel you are interested in if you would like for it to remain top secret... he can give you some valued insight... he is the fitment guru
neuronbob
23
Jul 16, 2019 10:48 AM
BreezyTL
Jul 26, 2016 12:52 PM
SinCityTLX
55
Oct 11, 2015 01:20 AM
Ratheruneeq
Sep 28, 2015 07:41 AM
bailey24
Aug 31, 2015 05:38 PM
