OEM Wheel Specs
Old 10-22-2007 | 10:40 PM
JFaz's Avatar
OEM Wheel Specs
Will the 2007 TL OEM 17" fit a 2005 TL?
What is the wheel width, diameter, offset and hub hole diameter of the 2007 TL stock wheel?
What is the wheel width, diameter, offset and hub hole diameter of the 2005 TL stock wheel?
Thanks for the help.
Old 10-23-2007 | 05:05 AM
marshall28's Avatar
I believe they have always been the same.
17x8.0 +45 offset
Old 10-23-2007 | 09:12 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
Hub - 64.1 (as it has always been for most if not all honda/acura)
The 04-06 base rims fit 04-08 6speed and Auto
The 07-08 base rims fit 04-08 6speed and Auto
The 07-08 type s rims fit 04-08 6speed and Auto
Old 10-23-2007 | 09:32 AM
JFaz's Avatar
Thumbs up
Thanks! I just picked up a set of 07 stock rims to put on my 05. Now the question: Which tires should I put on them? I have read "Inacurrates" thread on 255/40's, it's got me thinking.
Again, thanks for your help.
Old 10-23-2007 | 09:43 AM
t0talacuratl's Avatar
Green Machine
There might be a difference between the 04-06 and the 07-08 wheels. Remember that the 07-08 TL's (except TL-S) does not come with brembo brake system, so they might not be as wide. IMO, those wheels look smaller than the 04-06.
Old 10-23-2007 | 10:37 AM
JFaz's Avatar
I posed the question to the Service Manager at a local Acura dealer and his response was,"according to our information the wheel specs are the same."
Old 10-23-2007 | 10:46 AM
chill_dog's Avatar
Oderint dum metuant.
All wheel specs for the 3G TL are the same, save the ASPEC wheels (18X8.5 in 04 and 18X8 for 05+); any 3G wheel will fit on any 3G. 06+ wheels are TPMS compatible.
Old 10-24-2007 | 08:19 AM
94 DC4 RS LSV/Turbo
on 17" wheels you have so many different sizes you could run
1 - 245/40 17 <- I would go with
2 - 255/45 17
3 - 235/45 17
4 - 235/40 17
5 - 245/45 17
Old 10-26-2007 | 01:54 AM
JFaz's Avatar
What about 255/40 x 17's?
You are right...to many options.
Old 10-26-2007 | 10:08 AM
chill_dog's Avatar
^^^You want to discuss 255/40's? Here's everything you could want to know and then some...
https://acurazine.com/forums/showthread.php?t=135535
Old 04-24-2008 | 07:14 PM
Sylvain's Avatar
Question 2004 --> 2008
So that means that my 2004 base TL OEM wheels (winter set) will not fit the latest TL models with TPMS?
Old 04-25-2008 | 08:15 AM
chill_dog's Avatar
^They will fit, but as is, the TPMS won't work; you'll have to get TPMS sensors and mount them on the 04-05 wheels.
Old 04-25-2008 | 02:50 PM
Sylvain's Avatar
Question TPMS on 2004/2005 Wheels
OK. Good. I thought you meant that TPMS sensors could not be mounted on 04/05 wheels. I guess they can, it's just that sensors didn't come with the wheels in 04/05.
rseb4agze
05-03-2016 08:41 AM
nanos
11-12-2015 09:41 PM
merc009
10-03-2015 01:59 AM
mtl_ilx
09-03-2015 10:48 AM
MyKids&Cars
09-01-2015 01:53 PM
Quick Reply: OEM Wheel Specs
