Newbie A-Spec susp question
I've done a couple searches but need another piece or two to complete the puzzle. Once the A-spec upgrade has been decided upon, the consensus seems to be to go with the 'MT older version'. Thanks to an old post from Kro I found several item numbers. However, I am unsure exactly which one matches up. The item numbers listed only 2 A-spec (08W60-SEP-200 and *.201A) while the rest were broken down between Sport AT MT older and newer. What is the item number for the 'Older A-Spec MT'? Also, most of the listings on Ebay list the *.200 (A-Spec AT older) but some list the *.202A. Which one is that?
Thanks!
Thanks!
When it ends with "A", I believe that means it's for Manual.
Part # 08W60-SEP-200 - A-spec suspension set for model year 2004 - 2006 w/automatic transmission. The ....-201A is for a 2007 - 2008 w/automatic transmission.
Check with your local dealer, they have an A-spec catelog at the parts department.
Good luck
Good luck
Thanks for the replies. Since there are so many of the 200A for sale and the prices are reasonable I am probably going in that direction. However, other posters have said the stance would be better with the MT version. I will check out the dealer and see if I can get my hands on the A Spec catalog unless someone has the number handy.
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
4drviper
09-23-2015 07:42 PM
