New Wheel/Tire specs thread with pics
Old 02-17-2005, 04:14 PM
cM3go's Avatar
Rules of this thread. Much like this thread: https://acurazine.com/forums/showthread.php?t=15225
Difference, a little more info and post a picture of your car with the wheel/tire combo so users know what it looks like on your TL. To host a picture, use www.imageshack.us.
This is mine for an example, you need not post your stock setup if that is all you have.
Post only specs and pic, no additional posts, if you have a question or comment about a user's wheel, please PM them
1.Brand of Rim - OEM Enkei
2.Rim size (diameter and width) - 17" x 8"
3.Offset - 45mm
4.Brand of tire - Pirelli PZero Nero M+S
5.Tire size - 235/45/17
6.Drop Type and Amount - Comptech 1" drop
7.Do they rub - No rubbing
8. Transmission type (use of spacers if 6MT) - 6MT no spacers
9. Picture
The following 4 users liked this post by cM3go:
afuqua2 (08-14-2011), Garriock (04-14-2012), marcar74 (10-27-2015), Xavier Molina (02-15-2012)
Old 02-22-2005, 05:49 PM
clay8898's Avatar
1.Brand of Rim- Velocity 898
2.Rim size (diameter and width) - 20x8
3.Offset - 45mm
4.Brand of tire - Sumitumo
5.Tire size - 245/35/20
6.Drop Type and Amount - none
8. Transmission type (use of spacers if 6MT) - 5AT
9. Picture
ROKET (12-20-2023)
Old 02-22-2005, 06:00 PM
clay8898's Avatar
3.Offset - 45mm
4.Brand of tire -Sumitumo
5.Tire size -245/35/20
8. Picture
[IMG][/IMG]
Her's a bigger pic.[IMG][/IMG][IMG][/IMG]
Old 02-22-2005, 06:08 PM
clay8898's Avatar
closer pic of the wheels
[IMG][/IMG]
Old 02-23-2005, 10:00 AM
Team Nighthawk Member
SKIUL8R's Avatar
you may want to add if you have an AT or MT since there is a difference in fit
APB-TL (11-15-2012)
Old 02-26-2005, 04:29 PM
jacobtree's Avatar
I want to upgrade to something bigger then 17' wheels, but do not want the smooth drive to be effected. Whats the biggest I can go with out it affecting my drive?
tazcy (04-16-2012)
Old 02-27-2005, 09:27 AM
jacobtree's Avatar
I am looking into putting bigger wheels/tires on my 05 TL. What is teh biggest I can go with out have troubel with rubbing, and the smooth drive I have now?
Old 03-03-2005, 08:15 PM
Registered VTEC junkie
jchcmax's Avatar
1.Brand of Rim - SSR Competition
2.Rim size (diameter and width) - 18" x 8.5"
3.Offset - 42mm
4.Brand of tire - Falken 451
5.Tire size - 245/40/18
6.Drop Type and Amount - No drop
7.Do they rub - No
9. Picture
Old 03-04-2005, 11:24 AM
Just put on my new 18s
I went the 18"s because of ride quality and I have damaged wheels before with sidewalls that were too thin.
1. Brand of Rim - Ronjon
2. Rim size (diameter and width) - 18" x 8.5"
3. Offset - 42mm
4. Brand of tire - BF Goodrich T/A g-Force T/A KDW2
5. Tire size - 255/40
6. Drop Type and Amount - none
7. Do they rub - No rubbing
9. Picture
Old 03-05-2005, 01:42 PM
I6
6mtV6's Avatar
1. Brand of Rim - Enkei PK6
2. Rim size (diameter and width) - 18"x8.5"
3. Offset - 35mm
4. Brand of tire - Falken ZE-512
5. Tire size - 245/40ZR18
6. Drop Type and Amount - None
9. Picture
Old 03-08-2005, 10:03 AM
SKIUL8R's Avatar
1. Brand of Rim - Maya DMT
2. Rim size (diameter and width) - 19"x8.5"
3. Offset - 36mm
4. Brand of tire - Michellin Pilot PS2
5. Tire size - 245/35/ZR19
9. Picture
Old 03-08-2005, 08:32 PM
Spryster's Avatar
My 19's NBP
1.Brand of Rim - FOOSE Speedster
2.Rim size (diameter and width) - 19" x 8.5"
3.Offset - 42mm
4.Brand of tire - NITTO 555 EXTREME ZR
5.Tire size - 245/35/19
6.Do they rub - No rubbing
7. Transmission type (use of spacers if 6MT) - 5AT
8. Picture
Hauserjoe40 (10-13-2013)
Old 03-08-2005, 09:27 PM
3rd Gear
esqrz's Avatar
just confirming
i like your setup and am planning to do the same (for the same reasons). can you confirm that you have 255/40's on the rims? everyone that i have spoken to says that 255 is too big for a 8.5 inch rim?
thanks!
3. Offset - 42mm
8. Transmission type - 5AT
9. Picture
Old 03-09-2005, 10:10 AM
260 HP's Avatar
Suggestion to 6MT owners: please add if spacers are needed to clear the Brembos.
Old 03-10-2005, 08:57 AM
acur8ly's Avatar
1.Brand of Rim - ADR Sterling
2.Rim size (diameter and width) - 18" - 8.5"
3.Offset - +38mm
4.Brand of tire - Toyo Proxes 4
5.Tire size - 235/40ZR18 95W
Old 03-11-2005, 07:59 AM
DWM Jr's Avatar
SSR Looks Right
Do they come in17?
Old 03-30-2005, 06:56 PM
7th Gear
jbennett's Avatar
1. Brand of Rim - RonJon Inspyre
3. Offset - 42mm
4. Brand of tire - Falken Ziex ZE-512
5. Tire size - 245/40ZR-18
6. Drop Type and Amount - A-Spec suspension kit (~1/2")
9. Picture:
Old 04-03-2005, 07:53 PM
TL4 Midlife's Avatar
2004 WDP on 20" Rims
Hello All!
Here is the info:
Rims: Foose Lusso's
Tires: Nitto 555's - 245/35/20
Stock Coils
Comptech Swaybar
Comments are welcomed!
Old 04-03-2005, 08:59 PM
SGT SLAUGHTER's Avatar
1. Brand of Rim - ADR Sterling
2. Rim size (diameter and width) - 19" x 8.5"
3. Offset - +38mm
4. Brand of tire - Kuhmo Ecsta Supra
5. Tire size - 235/35ZR19
6. Drop Type and Amount - stock
9. Picture
Old 04-04-2005, 01:00 AM
WDP on 20's
1. Brand of Rim - Foose Lusso
2. Rim size (diameter and width) - 20" x 8.5"
3. Offset - 45mm
4. Brand of tire - Nitto 555
5. Tire size - 245/35/20
6. Drop Type and Amount - Stock
9. Picture
Old 04-04-2005, 03:39 PM
prozzi's Avatar
1. Brand of Rim - TSW Rib
2. Rim size (diameter and width) - 19" x 8"
3. Offset - 35mm
4. Brand of tire - Proxes 4
5. Tire size - 245/35/19
8. Transmission type - 6mt
9. Picture
Old 04-07-2005, 03:46 PM
beng55's Avatar
3. Offset - 35mm
9. Picture
My first post
...Im going to pick up a 6 MT Saturday. I currently own a A4 1.8t and Ill be getting rid of it. I love modding my cars but I am new to Acura. I currently run a set of BBS CH (18 in)...I know plenty about wheels for german cars but next to nothing about wheels for Japanese cars.
That said...I love your wheels...I checked them out and would love to pick them up in the anthracite finish with the polished lip. I'd like to buy em and mount em ASAP...but I dont know a damn thing about Enkei...how's the quality? Have you had any problems with the finish or the wheel's strength?
As soon as I have my car ready to go...Ill post it.
TIA for answering my questions.
Old 04-10-2005, 08:35 PM
TLJohn's Avatar
Privat Kraftwerks
1. Brand of Rim - Privat Kraftwerks
3. Offset - 35mm
4. Brand of tire - Pirelli NeiroZero
7. Do they rub - With car loaded up with five people there is a slight rub
9. Picture
The polished steel lip looks a lot better in person than in the pictures. It catches the sunlight and really makes the wheel look cool. It also reflects the blue LED courtesy lights at night.
Old 04-10-2005, 08:52 PM
dragonlord's Avatar
My pics
1. Brand of rim: Enkei
2. Rim size: 18 X 8
3. Offset: +40
4. Brand of Tire: B.F. Goodrich g-force TA KDW
5. Tire size: 245/40ZR18
6. Drop type and amount: None
7. Do they rub: Haven't found any yet
8. Transmission type: 5AT
9. Picture:
Old 04-11-2005, 10:20 AM
Treblig's Avatar
1. Brand of Rim - Konig Prophets
2. Rim size (diameter and width) - 18"x8"
3. Offset - 38mm
5. Tire size - 245/40/18
6. Drop Type and Amount - A-Spec Suspension
9. Picture -
Old 04-22-2005, 10:50 PM
caldoone's Avatar
Question Momo Fighter Rims
Fellas...I need some help.
I'm sitting here ready to hit the "send" button to order these bad boys from 1010tires.com but they give me this lame fitment notice.
The Momo Fighter 18" wheels will not fit a 2005 Acura TL.
18x8 - 42mm - 5/114.3
42mm is a too low offset for a 18x8 wheel.
Is this true??? Any help you guys can give would be greatly appreciated.
'05 TL w/Nav 5AT_NBP/Ebony
Old 04-25-2005, 12:32 AM
jamesjermia's Avatar
1.Brand of Rim - panther - emr 429 intimidator
2.Rim size (diameter and width) - 17" x 7.5"
3.Offset - 45mm
4.Brand of tire - Nitto NT NeoGen ZR
5.Tire size - 225/40/18
6.Drop Type and Amount - None
Edit by MOD: cTLgo
Old 04-25-2005, 12:40 AM
3.Offset - 45mm
http://img33.echo.cx/img33/1619/dsc011287kq.jpg
Old 04-29-2005, 05:31 AM
drksyd's Avatar
1.Brand of Rim - Foose
2.Rim size (diameter and width) - 20"x8.5"
3.Offset - 34mm
4.Brand of tire - Toyo Proxes PX4
5.Tire size - 225/35/20
Old 05-04-2005, 02:51 PM
Automobile Aficionado
Twenties's Avatar
3.Offset - 34mm
nice. very nice. by that picture i'm thinking Hollywood Hills, Mulholland, or Palos Verdes. My friend (a chick) has these same rims in 19" on a Black TL. 20's fits well and next time you can try a 245/35 it'll likely work despite your low (34) offset .,.....since your only 8.5 on width.
Old 05-10-2005, 04:00 PM
Tom Champagne's Avatar
WDP with new shoes
1.Brand of Rim -Moda R6
2.Rim size (diameter and width) - 18x8
3.Offset - 45mm
4.Brand of tire -Yokohama AVS db2
5.Tire size - 245-40-18
Old 05-10-2005, 05:53 PM
Shibby's Avatar
1. Brand of Rim - Ronjon Inspyre
3. Offset - 42mm
4. Brand of tire - Toyo Proxes 4
5. Tire size - 235/40
9. Picture
Old 05-11-2005, 04:49 PM
HOOD FIRE
J Hood Holla's Avatar
Talking Ok Now...!!!
Little Kidz Need To Step Up Their Game Alittle. Why Get A $35,000 Whip And Not Have Some Nice Shoes!!! There Is Only About 3 Or 4 People On This Site Wit Kinda Hot Rims And U Know Who U R!!! Peeps Spend Some Money On Your Baby...stop Being Poor!!!
$3500 On The Dubs Well Worth It...cuz It Will Be Da Mos Blazin Tl Out There!!! Hood Fire
Pics...yeah Comin Soon, Hopefully Somebody Steps Up And I Get To Show U The Whole Custom Job On Hood Fire...if Not Only The Blades!!!!
Hoodz Out
The following 3 users liked this post by J Hood Holla:
getu1 (05-09-2012), nizzle902 (07-11-2013), oneeb97 (08-13-2016)
Old 05-11-2005, 09:16 PM
dragonlord's Avatar
It's not all about who spends the most-it's about everyones own personal style-not just fads!
Old 05-18-2005, 05:56 PM
sharontha's Avatar
1.Brand of Rim - Ace
2.Rim size (diameter and width) - 19x8.5
3.Offset - 38mm
4.Brand of tire - Hanook
5.Tire size - 235/35/19
9. Picture
Edit by MOD: cTLgo
Old 05-27-2005, 02:58 AM
5th Gear
nkegol4girl's Avatar
1.Brand of Rim - Racing Hart J5 Pro
3.Offset - 45mm
4.Brand of tire - Toyo Proxes T1-S
5.Tire size - 243/35/ZR19
8. Transmission type - 6MT
9. Picture
The following 2 users liked this post by nkegol4girl:
bored7one4 (06-11-2012), The Haitian Sensation (06-17-2012)
Old 05-27-2005, 12:57 PM
mglzerimar
mglzerimar's Avatar
The following will take you to rapidshare site, go to the bottom of the page & select free viewing. Then you'll see my ride.
http://rapidshare.de/files/2012944/MVC-008S.JPG.html
http://rapidshare.de/files/2012939/MVC-007S.JPG.html
http://rapidshare.de/files/2012947/MVC-011S.JPG.html
Old 05-27-2005, 04:03 PM
mglzerimar
mglzerimar's Avatar
  • 05 TL
  • 20" Konig
  • 30 series tires
[IMG]MVC-007S[/IMG]
[IMG]MVC-008S[/IMG]
[IMG]MVC-011S[/IMG]
Old 05-27-2005, 05:08 PM
mglzerimar
mglzerimar's Avatar
rim.Konig
size.20x8
tire brand.nitto
no drop
no rub
5AT
Old 06-05-2005, 01:23 AM
ASP
Earl Shod
ASP's Avatar
1. Brand of Rim - TSW Catalunya (Hyper Silver)
2. Rim size (diameter and width) - 18" x 8"
3. Offset - 40mm
5. Tire size - 245/40-18
Quick Reply: New Wheel/Tire specs thread with pics
