New tires
Your going the wrong direction. The factory Michelins are 25.6" and the 245/40-17 you're recommending is only 24.7" tall and they would look like roller skate wheels if installed on the TL and the gap would be considerably wider. I sound like a broken record, go with 245/45-17 at 25.7". Just an FYI, the 235/50-17 are tall, 26.25".
AZ Community Team
Received 7,770 Likes
What you're saying (and maybe what others besides me have been missing) is that a "normal" 235/45-17 tire is about 25.3" overall diameter. BUT the OE 235/45-17 is actually 25.6" diameter.
25.6" diameter (the slightly tall OE 235/45-17 size) is CLOSER to the diameter of most "normal" 245/45-17's (25.7" diameter).
You know, you posted this before and I didn't "get it" right away.
Just for example, using a 235/45-17 all season tire:
OE included in the following:
Wear rating 260-740
Speed ratings H,V,W,Y
Load rating 93-97
Section width 9.2"-9.6"
Tread width 7.5"-8.6"
Diameter 25.3"-25.6"
Hard to believe that within a specific all season tire size there can be so much disparity, especially in the wear rating, 260-740, and also the tread width, 7.5"-8.6", 1.1" per tire difference and that equates to a total of 4.4" more rubber on the ground.
Before anyone mentions that the wear rating isn't based on an industry standard, let me say that although this is true, it will be a safe bet to assume that a tire with a 740 rating will see much longer life than one with a 260 rating.
Thought I'd post the 245/45-17 all season tire for comparison, keeping in mind the 235/45-17 OE Michelin dimensions in ():
Wear rating 160/560 (300)
Speed ratings H,V,W,Y (W)
Load rating 94-97 (93)
Section width 9.4"-9.7" (9.6")
Tread width 7.6"-8.8" (7.6")
Diameter 25.6"-25.8" (25.6")
CostcoFanAUS
09-18-2015 06:05 AM
