New HT-SPEC chassis bracing set for '04-'08 TL
I found these new braces for our 04-08 TL. There are two 4-point braces, tie bars, and subframe connectors. listed $510 on heeltoe auto. Anyone have them yet? http://www.heeltoeauto.com/HT-Spec-C...-pr-65463.html
There's a large thread started by heeltoe on these.
tlwith2carseats
I just got my kit in....tryin to find time to install. i know there is alot of conflit of opinion about bolt in subframe conections, so i decided to just buy em and check em out. i like the acura tl, but the handling characteristics are not the best...i know it will never handle like my awd 3 series (which isn't the best, but is fuckin awesome on the mountain roads by my house) but there should be room for improvement. i'm a single father, so time is hard to come by, but if i get it installed, i'll let you know what i think.
lol i bet it will make a huge difference.. but the only thing i worry about is bottoming out on the bars. my car is slammed and my jpipe already scrapes the speedbumps goin super slow
tlwith2carseats
so far installed the front and rear conections, just not the sides cause it was like 11 p.m. and i was tired, but so far pretty easy, and like mr. heeltoe said, not really that low, but car is still in the air. if i get time 2night i wanna finish it up and give it a test. and as for weight, if i remember correctly, the shipping weight of the entire package was 38lbs.
Former Sponsor
The basic brace package with the side sills, rear brace, and front lower arm bar weighs about 25-30 lbs, give or take. It isn't horrific, but it isn't anything. You'll see the car feel more communicative more than any decrease in performance, especially since the added weight is so low to the ground.
Former Sponsor
The side sills can be a bit tricky because the hardware is designed to work on holes that are not threaded. It might help to use a jack-stand to support the brace at one end as you bolt in the other end. You'll get it, but you will wish you had another arm or two.
tlwith2carseats
ok...started raining so i didn't do sill's (^thanks for the advise^), but i just test drove car with front and rear braces from ht-spec kit...
****i do not claim to be an expert on anything related to cars. i know alot, but there is always someone who is going to know more than me. but a brief history on me:
i used to drive proffesionaly (a.k.a. they paid me) for a company that was local (ima just not say the name of the shop cause it's really of no importance) i raced for them for 2 seasons before my child was born in an amateur "nas-truck" (basically a pick-up that was set up like a nascar. while it was amateur, i drove all over - maryland, south carolina, pennsy. it was really just a hobby and a way to promote the shop.
i buit my own chassis for my 1927 ford. got two frame rails and started welding till i had a car. owned the car for about 5-6 years or so with no issues. so i know a little bit about suspensions.
that being said...so far...best purchase i made for the tl. without a doubt. everything about the suspension so far has been improved. i havn't pushed it to the max yet cause it was raining , but while the change is subtle, it's amazing (if that makes sense.) and best part of all...for some reason i do not know why...exhaust sounds better... seriously have no clue why, but it does.
i snapped a couple pics, will try and put em up 2marrow. if you wanna know more, just let me know, but i am seriously impressed with this kit..
How does it feel over bumps? Any change in rattles? I have a feeling the ride over bumps will be the biggest change.
Thanks for the review.
tlwith2carseats
damn, "i hate cars"..you are good. so far, the biggest improvement was over the bumps. one thing i never liked about the tl was the way it had almost bump steer. like on certain turns, hitting a bump would cause the front end to hop to the left or right. seems to have solved the issue, but just general bumps in the road seem less drastic as before, almost like takin air out of over inflated tires is the best way to describe it. i would think that the sill bracing would do more for the rattles, but i dynomated all the week spots in my door panels and center console, so i have very little rattle to begin with. change in the exhaust sound for me seems to be coming more in the area of the j-pipe.
i am not trying to make a race car, or track car...i already have/had those. just want a fun daily driver that is safe and comfy when my daughter is in the car, and then a blast to drive when she is out of the car.
Former Sponsor
FYI we sent out more detailed info on the HT-Spec brace packages in our email newsletter today.
v 4910shp/19,600ft-lb v
njtl06, have you noticed any fishtailing or the rear end "slipping" to the side under moderate to slightly heavy braking after installing the full set?
I have the full HT-spec set and noticed this a few times after the past few weeks. I thought it may be old tires, but I just got 4 new Cont. DWS's along with a front-end alignment.
Thanks.
Thanks.
2004 NBP TL 6MT
Thanks.
Thanks.
Former Sponsor
Thanks.
Thanks.
You need to put more information...what brakes and suspension are you using? Have a rear sway bar? What are your alignment settings?
All these are potential reasons for instability during braking. Anything that was happening on the car before you put bracing on is amplified when you brace it. So this could be something that was happening low level before you just didn't notice it maybe.
Stock brakes and stock suspension. I'm going to have my brakes checked out this weekend (straight line braking, the car's front end will "dive" right, and the rear will go left.
CT Sway bar and I'm assuming stock spec front-end alignment for the tire place.
Certainly appreciate all of the help!
Former Sponsor
If all is stock that could be part of the problem there. Neither the stock brakes or suspension are very confidence inspiring because of their realtively un-sporting design.
I would tend to think this could really be a tire issue as well. If those are stock they are obviously un-sporting and very nervous. Are they stock tires also? Even if they are not it could be an inflation issue or a defective tire. Swap tire left and right if theyu are non-directional, or front to back if they are, to see if there is any effect.
I suggest waiting to install the rear swaybar until you get this fixed. The bar will likely mask the real problem and make it harder to find.
Ok, for the follow-up. It appears I should stay at the my current job and not become a mechanic.
Evidently, the rear brace was not tightened enough and therefore the rear suspension became loose over time (just a few hundred miles). So, my mechanic ended up re-torquing everything and did a 4-wheel alignment. Car drives perfect now and the turns have become fun again...
Chapter Leader (Central New Jersey)
Sorry to bring the thread from the ruins but is this the kit you guys are referring to?
http://www.heeltoeauto.com/ht-spec-c...s-ua6-ua7.html
takin care of Business in
Received 4,732 Likes
sub'd
Ah, hamburgers!
For the folks who have utilized this entire kit, which one component out of the three do you guys recommend as the first step towards chassis stiffening?
I can only afford to do one at a time plus the kit isn't that much less expensive than buying the three separate.
Ah, hamburgers!
What did you torque your bolts to on the side bars?
Ah, hamburgers!
For anyone who cares, I have installed the front and side sill braces so far (can't wait for the rear brace) and I wholeheartedly agree with njtl06. The effect is just so damn amazing.
MMkay.
I am intrigued. I'd like to hear more about it from people with lowered cars. My car was slammed, and I'm hoping to get it back to that Lowness but also wouldn't mind adding a little bracing to improve the handling as long as i won't drag these exiting a driveway or something.
In comparison to the exhaust/front subframe, how much lower do these braces sit? anyone have pictures?
My first ricer
Does anyone know if the fender braces from the Accord Euro (TSX) fit the TL also? Just curious if it would be worthwhile on a TL too.
http://www.ebay.com/itm/ULTRA-RACING-3-POINT-FENDER-BAR-SUPPORT-BRACE-FOR-02-07-HONDA-ACCORD-EURO-R-CL7-/190662461705?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AAccord&hash=item2c645e4909&vxp=mtr
I found all 4 pieces on eBay (fender braces, side, front, and rear) and it works out under 700 with free shipping and most of the sellers have a or best offer kinda thing so probably a few bucks off.
lanechanger
10-13-2015 10:56 AM
