New alignment
Old Mar 28, 2008 | 03:40 PM
george3761's Avatar
2007 TL Type-S
New alignment
Question for the experts. I just got 18" wheels and 245/40/18's instead of 235/40/18's. Should i have the alignment checked?
Old Mar 28, 2008 | 06:39 PM
Jesstzn's Avatar
A tire / wheel change shouldn't effect the alignment.
What kind of wheels? ( Not that it matters ).
I live just north of you.
Old Mar 29, 2008 | 12:53 PM
george3761's Avatar
2007 TL Type-S
Yes you do. We love to backpack around Trail and Nelson.
Here's the link for the wheels.
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
Old Mar 29, 2008 | 01:38 PM
01tl4tl's Avatar
Its never a bad idea to get the alignment checked- then adjusted if not perfect spec.
Just driving on Earth will cause a need for adjustment! Potholes- road construction, curb slaps...
Tires are expensive, so is gasoline- wheels going the correct direction with no scrub effect are better than ones pointed in or out
Get a 4 wheel thrust alignment- and dont let them bs you
The only adjustment on a stock TL is the toe, and it should read close to zero when done and the camber should be zero if nothing is bent, a little negative camber is good and happens when you lower the car.
emailnatec
29
Sep 28, 2018 04:27 PM
Jul 16, 2017 07:33 AM
Zonian22
Nov 14, 2015 01:20 PM
TxRzrBk
Sep 17, 2015 01:07 PM
