Need help changing rotors on 06 TL 6-speed?
Rotors should slide right off after you take off the caliper unless you havent taken off those two phillips heads that are on the face of the rotor. I took mine off and never put them back on since its useless.
Heres a detailed with pics write up.
https://acurazine.com/forums/3g-tl-2004-2008-93/d-094-diy-complete-brake-job-pics-624404/
3G Garage: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
D-041: Brakes-front/rear caliper overhaul, front/rear pad replacement, brake bleeding, brake disc specifications, parking brake adjustment
https://acurazine.com/forums/showthread.php?t=118283
D-085: Front and rear Brake disc (rotor), knuckle, hub, and front wheel bearing replacement
https://acurazine.com/forums/religion-politics-18/world-opinion-132940/ - with Service Manual Scans
